Threadripper PRO 9995WX $12,000 mod turns heat spreader into a water block, stays under 50°C at 1,550W
1.7k 947
On the results side, the channel reports an all-core overclock of 5.325 GHz and Cinebench R23 over 205,000 points, with Cinebench 2024 reaching 10,080 points and Cinebench 2026 at 41,478 points. During the Cinebench 2024 and 2026 runs, the CPU package power is shown around 1,340 W, with core temperatures generally in the 30°C to 50°C range, while the total system draw is reported around 1.7 kW.
https://videocardz.com/newz/threadripper-pro-9995wx-12000-cpu-mod-turns-heatspreader-into-water-block-sub-50c-at-1550w
