Rumor: NVIDIA Ampere GeForce RTX 3070 and RTX 3080 specs surface
Andrew
1.1k 548
On both Asia based mydrivers and on a twitter account from ‘KittyCorgi’ info has appeared on two new NVIDIA GPUs, allegedly Ampere microarchitecture based. Two GPU models are named, GA103 GPU (RTX 3080) which would get 60 SMs (Streaming Multiprocessors aka shader core clusters) and then there is a mention of GA104 with 48 of them (RTX 3070). The GPU IDs seem to be reversed for whatever reason, we know, again rumors. If you multiply the clusters with 64-shader procs per cluster (which is what NVIDIA historically has been doing) each then you'd see 3840 Shader processors and 3072 shaders processors respectively. The leak mentions a 320-bit bus for RTX 3080, which could mean a 10GB memory GDDR6 configuration.
Im actually surprised that the memory specs have not gone up this generation. Don't get me wrong 10Gb is fine for most applications/games but I was half expecting Nvidia to pump up the memory...but of course nothing is confirmed yet.
