AMD's Phoenix APUs to Leverage Performance and Efficiency Cores for Optimal Balance
According to the AMD Processor Programming Reference (PPR) guide for AMD Family 19h Model 70h CPUs (AMD Zen4/Phoenix), the hybrid architecture may support two types of cores: Performance and Efficiency.
Those names are very similar to what Intel uses for their hybrid design (Performance/Efficient Cores). This also indicates that hybrid architecture is coming to consumer CPU space. What should be noted is that the naming in the programming guide may not necessarily reflect the name that will be used for marketing purposes.
Source: https://videocardz.com/newz/amd-hybrid-phoenix-apus-to-feature-performance-and-efficiency-cores
