OLED Experiences - 2 years in
...had a chance to thoroughly check at a 65 inch LG G3 w/MLA recently...wow. We don't need a new tv / monitor just yet, but when the time comes, a big LG MLA OLED is on top of the menu.
Meanwhile, some more new eye candy for all you diehard OLED / Dolby fans...
these vids compliment OLED visuals with Dolby sound variants...
...& some more OLED eye-candy
...speaking of eye candy, some CP2077 4K path-tracing and FS 2020 from earlier this evening, looks great on OLED 😀
...not sure what to call this genre, but it also has some nifty Dolby Vision and Dolby Atmos in. Enjoy...
Some more Dolby Atmos "Ray Tracing Audio' 🤔 goodies; some visuals are also stunning. Second vid is an hour long Dolby Vision HDR, again with some gorgeous scenes in it. I also had another look at the 55 inch LG C3 and G3; C3 is hard to distinguish from earlier OLED 'C' line. All are quite stunning, but the G3 is brighter than the others, likely due to the addition of MLA (micro lens array).
...and another one of these to enjoy your OLED investments... btw, have been watching the price of a LG G3 MLA dropping just a bit
@bonami2, @Sir Beregond and all other OLED fans ...this is definitely worth watching on your OLED (including sound at 1.20 min and onwards). While few will have an 8K HDR 240 FPS setup, this is one of the best-produced demos I have seen...😀
Il try to check that tonight. 😀.
Havent ran my pc in week. Haha
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
32" 4K OLED 240Hz can't arrive soon enough.  I plan to run custom Super Ultrawide resolutions like 3840x1440 but at 240Hz, double that of what I can do now with the LG C1.  The higher DPI and nits will be awesome.  However, ASBL/ABL and lack of BFI will suck. Man BFI at 240Hz will be nutz.
  • 4 weeks later...
...after close to 2.5 years, I finally had a 'stuck pixel'...two rounds of the Pixel Cleaner option and that was that, for now at least.
Also:  OLED 48 + 4090 + 7950X3D +  DLSS 3.5 w/ ray reconstruction = 😀
Wait what is that an option in the tv menu? I think i got a few dead pixel.
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
...I had one pixel on my C1 that was stuck on white-greenish, so not 'dead dead'. If you go into the LG menu, look for support > OLED Care > OLED Panel Care > Pixel Cleaning... takes a bit more of an hour (per onscreen instructions, can't use the monitor/tv then), but it will turn itself back on when done. I had to do two rounds and then it was back to normal.
Will check for sure 😄 Thank you
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
Is there some sort of screen or something you are using to identify stuck pixels (or any signs of burn in) where its all one color or something?
Just sitting at my desk i got 20/20 eye from laser surgery. I see some black pixel or at least they arent the good color.
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
...Pixel cleaning won't fix really 'dead' pixels but they can get stuck on a specific colour, including black - have to figure out which one is which. Using an all-black background (desktop setting will do) and then an all-white and an all navy blue one usually helps to identify which pixels need attention cleaning. The one pixel that needed attention on my C1 was dead center both horizontally and vertically...as mentioned, I did two rounds of pixel cleaning. The pixel had clearly improved by more than 50% after the first round (recalling that it was stuck white-green). Second round seems to have fixed it.
From what I heard, that's the only time you should run the manual pixel cleaning (the one that takes an hour) is if you identify issues like that. If I recall the C1 does a mini refresh every 4 hours of cumulative use when it goes on standby and a full one every 2000 hours. I'll have to look into that because aside from stepping away for say 15-20 minutes sometimes (where the LG screen saver comes on) I usually turn the screen off so I wonder if its not doing the mini cleanings/refreshes.
95% of time i turn it off with the remote.
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
I've used this before, not sure if it will help you but might be worth a shot.
https://deadpixeltest.org/
Still haven't had any issues with my CX. I'm at 2190 power on hours currently. I always turn it off when I'm not using it. For stuff like Folding@Home I keep the LG off and just access the computer from one of my other PCs via RDP.
CPU: 5900X + Optimus block
MOTHERBOARD: MSI X570 Ace
RAM: 32GB Oloy Blade 3600CL14
SSD/NVME: 1TB SN750 Black
SSD/NVME 2: 1TB SN750 Black
GPU: Reference 6950 XT
...now that my C1 OLED pixels are clean and scrubbed, it's back to eye-candy...😁
I can't run 8k video because they end up
  • A: Abysmal
  • M: Mediocre
  • D Distorted
Damn chat gpt found that for me.
Wish they fix that on the 8000 serie. Great card except the 8k issue.
I have no idea how many hour i have on my oled need to check this.
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
  • A: Abysmal
  • M: Mediocre
  • D Distorted
...what, no 16K HDR card ? How do you make it through the day ? 🙃
...and some 7 hrs of 4K / James Webb
Wait what 16k?
Do youtube support that? Am on my phone can't check on pc.
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
28 minutes ago, bonami2 said:
Wait what 16k?
YouTube is being stingy, only 8K max on YT which my GPU does support
8k did run on my 6800xt with stutter.
Intel igp work fine in 8k
CPU: Ryzen 5560u
RAM: 2x32gb Sodimm
