Sapphire Radeon RX 7600 PULSE graphics card pictured, features 32 RDNA3 CUs and 8GB VRAM
What we are looking at today is likely the cheapest RDNA3 GPU thus far, the Radeon RX 7600 non-XT. The card pictured is the Sapphire PULSE model, which is typically Sapphire’s affordable option compared to the NITRO series. The new PULSE is a dual-fan and dual-slot design with a black cooler and some red accents. There is no sign of the RGB lighting on this model.
The Radeon RX 7600 is based on Navi 33 GPU with 32 Compute Units (2048 Stream Processors). The packaging confirms this configuration of the GPU as well as its memory capacity of 8GB. What the box does not say are the GPU and memory clocks, as well as the memory bus. The bus is what might limit the card’s capability because it is reportedly just 128-bit wide. Furthermore, AMD Navi 33 only supports up to 8 lanes in PCIe Express 4.0 standard.
https://videocardz.com/newz/sapphire-radeon-rx-7600-pulse-graphics-card-pictured-features-32-rdna3-cus-and-8gb-vram
