AMD Radeon RX 7900M “RDNA 3” Enthusiast Mobility GPU Specs Leak: Navi 31 With 72 Compute Units, 16 GB VRAM
1.6k 943
The red team is planning to launch a new flagship RDNA 3 mobility GPU which will feature the most high-end RDNA 3 ASIC, Navi 31, with MCM technology featuring 5nm GCDs and 6nm MCDs. Labeled as the Radeon RX 7900M, this new enthusiast-class chip will integrate a cut-down Navi 31 die. It will be a cut-down configuration so you won't be getting the same level of chip as the desktop GRE, XT, or XTX variants but it will be significantly more than the Navi 32 SKUs such as the 7800 XT.
WCCFTECH.COM
AMD is preparing its ultimate RDNA 3 mobility GPU and its most powerful laptop solution to date in the form of the Radeon RX 7900M.
