How to convert FLAC 5.1 to DTS 5.1, What software & encoder works?
HeyItsChris
Go to solution Solved by Cerberus,
  • Solution
CPU: 10900k
MOTHERBOARD: EVGA z490 DARK
RAM: 32GB 3600mhz G.Skill
GPU: EVGA 2080 SUPER
SSD/NVME: 970 EVO plus 1TB
CASE: Thermaltake Core x71
dts isnt free
try
WWW.VIDEOHELP.COM
LameXP is a graphical front-end for the LAME MP3, Ogg Vorbis and Nero AAC encoders. The Nero Encoder is *not* included in the...
or
WWW.VIDEOHELP.COM
Hybrid is a Windows/Linux QT-based frontend for a bunch of other tools which can convert most input formats to common audio & video...
CPU: 10900k
Well it turns out there are a lot of softwares out there that easily convert to DTS, but for some reason my receiver isn't passing thru DTS 16bit 1536kbps and maybe it supports 24bit over SPDIF, idk?  LG BH6720S.
I'm using Wonderfox HD Video Converter Factory Pro for use of converting any audio format nearly to DTS 5.1 16bit.
