Finishing Work Units
BWG
3 Attachments
Hi, I'm a retired editor from that blue flame place some of you came from. Been reviewing some eoc stats, and I found many who are outside of qrb probably due to shutting down your client before work unit(s) finish. Just thought i'd point out that when you're going to take a break, click the finish button first, and then let it finish the outstanding work. You won't fail work and reset qrb counters to possible another 10 successful work unit submissions.
Happy Folding!
Happy Folding!
Thanks for the tip. I understand what it was you were suggesting, but can you explain what "qrb" and "eoc" is?
EOC is a stats website: https://folding.extremeoverclocking.com/user_summary.php?s=&u=1208975
QRB is Quick Return Bonus and covered here: https://test.foldingathome.org/support/faq/points/?lng=en-US
