Project Glacier - Jan-Feb 2019
Tpbmods
2 Attachments
Hello EHW! I have decided to start off the modding sub-forum with all the projects I have completed so far in 2019!
Welcome to Project Glacier, the biggest headache of 2019.
After dozens of setbacks from terrible weather, waiting on parts from all over the place,
and tons of issues with paint... I present to you: Glacier
Mobo - ROG Maximus Code z370
CPU - i7 8700k Delidded/LM/Rockitcool Copper IHS
GPU - MSI 1080TI OC
Ram - T-Force TeamGroup Delta 2 RGB 16gb 4x4
PSU - Seasonic 850w Platinum
Storage:
M.2 - ADATA XPG sx8200 gen3 x4 240gb
SSD - Samsung 850 evo 500gb
SSHD - Seagate Firecuda 2tb
HDD - Seagate Barracuda Compute 4tb
Watercooling:
CPU - Alphacool Eisblock
GPU - EKWB EKFC1080ti
Pump - Alphacool Eisbaer d5
Radiators - EKWB PL 360
Temp Sensor - Thermaltake
Hardline Fittings - Thermaltake 16mm
Angled Fittings - Dazmode Darkside/Bitspower/Nanoxia
Drain Valve - Dazmode Darkside Pushvalve system
Misc fittings - Dazmode Darkside for a vast majority of them
Cables - Which I make myself!
Sleeving - Mainframe Customs Telios and Dazmode Darkside
Wire - 18awg that I ordered from PC Mods Canada
Connectors - Mainframe Customs and Dazmode (depends on the connector)
Pins - Mainframe Customs
Combs - v1Tech
Nice ! Gotta love that blue, glacier indeed.
Love the hard tubing for these build mods, myself I went function over form for my last WC build and went with standard black tubing mainly for ease and quick setup and due to the fact it was not meant for showing off haha. For my next build I really may have to consider going the hard tubing route. Out of interest what product did you use for the coolant coloring ? Again, this time round I went with nothing, one because you cannot see it and two I get nervous with the color additives as I hear bad things with regards to build up issues/gunk etc. I love low maintenance, so coloring was always a turn off for me. That being said most of the issues was back when Mayhems was having some issues, so it may be a moot point these days.
@ENTERPRISE I use Mayhem White Pastel UV Blue!
The fluid picks up the LED's really well, and with the addition of the UV led's firing from the front, it just pops!
I have one more build in the works that will be hardline, but then I will be making a pure softline build using the EK ZMT!
Project Blackout should be completed by the end of 2019!
@Tpbmods
Yeah it does pick up the LED's really well. Awesome, will look forward to both of those. As for the EK ZMT, I do not use that product specifically but in my current build I went for EPDM tubing. Oddly enough that product on EKWB's website is showing EOL, just as an FYI..but EPDM tubing is EPDM tubing at the end of the day, you can get it anywhere.
