Project 50 shades of grey - Canadian Amateur Modding competition 2018
Tpbmods
Taking a step back into Sept-Dec 2018 This was my CAMC 2018 Entry on the dazmode forums.
Components:
Mobo - ROG Maximus Code z370
CPU - i7 8700k Delidded/LM/Rockitcool Copper IHS
GPU - EVGA 1080TI FTW3
Ram - Teamgroup T-Force Delta 2 RGB 4x4
PSU - Corsair AX1000w (total overkill I know)
Storage:
M.2 - ADATA XPG sx8200 gen3 x4 240gb
SSD - Samsung 850 evo 500gb
SSHD - Seagate Firecuda 2tb
HDD - Seagate Barracuda Compute 4tb
Watercooling:
CPU - Watercool Heatkiller pro4 full nickle
GPU - EKWB Acrylic FTW3 TI
Pump - EKWB Revo D5 PWM
Radiators - Rad 1 - XSPC 360x45 Rad 2 - EKWB PL 360
Reservoir - Thermaltake 170mm
Temp Sensor - Thermaltake
Hardline Fittings - Thermaltake 16mm
Softline Fittings - EKWB 5/8 compression
Angled Fittings - Dazmode Darkside/Bitspower/Nanoxia
Bulkheads - Thermaltake/Nanoxia
Drain Valve - Dazmode Darkside Pushvalve system
Misc fittings - Dazmode Darkside for a vast majority of them
Tubing - Primarily Dazmode Darkside, But some Thermaltake in the mix.
Cables - Which I make myself!
Sleeving - Mainframe Customs Telios and Dazmode Darkside
Wire - 18awg that I ordered from PC Mods Canada
Connectors - Mainframe Customs and Dazmode (depends on the connector)
Pins - Mainframe Customs
Combs - A mix of Nanoxia CoolForce up front, and Dazmode darkside in the rear.
In the final hours, I actually won a facebook giveaway and got myself some Delta 2 RGB, which I decided I would swap to in the last minutes
Had a bit if dye fallout, which isnt that big of a deal. I didnt throw in anymore lights as it took away from the overall look.
Heres some photos of the final submission.
dZzDpeq.jpg&key=cb156b68225649b526c081c8403bd69460283a597712f6cb935ff072396f2120
Xbrv3L8.jpg&key=433f8886e27c2c8987c3c7ecbbebd558beec2943d95222d4aae97dc90b7c118a
cft8DGU.jpg&key=7259b2a91c4426bddc5a15d7975038b69aed3e18a6c3fefb0c70e1739f6ca352
YytJhF3.jpg&key=6299d0a5c7ae5462723152328d47d0f7f5c964b5bed2bb24f19ea7d4dba3f17e
XhgRbov.jpg&key=0b3fa447cb2d2ef04199db9f3fbeb1ae8ce6e4bf1c31123e2a67ca046ce4cf28
xLFuG2f.jpg&key=2e4317f44a459d9ecf9e25a15e03413b4028297aa50f0a86691266dd51020f3a
n3EZyLv.jpg&key=8c533c84613b3576892cd135afcfc029bd7a37ad68c4401d2df91c7481704b77
SUS116j.jpg&key=3ce71358ad450a49b5ea0b741b57f1a9a4a1f16f2383a8bb7d9e90df234884fc
AnwxK0q.jpg&key=978310778f4589f78373ab37b07f594cd429cec70ad3e9542af5a134717e481f
CQYbXME.jpg&key=53cf417176a9e01ed47f910a2c80e127fe38be357f4daab61270c5d306c2f15b
4BBRAkl.jpg&key=8a84cf8eaac14c899b82e5c16dc572b78ed49c9dc7c8d17f0da7eb2158c207e3
C1A2OD0.jpg&key=01d0f181b138a059aac5daa6d3e330eb40dd445f7b44c8e05f0e65debb934058
pEQiVzS.jpg&key=97b513624c1872266bd512151748f456484541ee8ba5f70e4be887d40a51e91a
HdIAye6.jpg&key=9fbd8655aa3aa8592def11c5ce859f52baba0d65c646a89470fd209be10ebbac
9YcnewW.jpg&key=b5dfa88d681ca83d3b93223fea3b9ec0593edea09b23a7a48dbca032c33e10da
  Reveal hidden contents
Oh nice ! Is the case fully custom I assume ? I love the fact that you carried on the mesh look by popping it around the reservoir as well, finishes it off nicely...that and the maple leaf at the case front of course :cool:
Oh and do not forget to enter: https://extremehw.net/forum/main-forum/promotions-contests/1532-ehw-inwin-insight-giveaway-inwin-805-gaming-chassis
Edited by ENTERPRISE
Thanks @ENTERPRISE, This was a phantek Evolv ATX that I blasted apart with a jigsaw ;) The case is absolute dogsh17 for airflow, so that was priority 1. Second was too give it a very raw and unfinished industrial look!
I will definitely share the giveaway, as I already follow and like everything. HOWEVER, I dont feel it would be fair for me to enter the giveaway sponsored by a company who already sponsors me :)
You certainly did attack it ! But in the best of ways. I would never have guessed it was the phantek Evolv to be honest, not after the work you did on it. Have you any current/upcoming mods ?
Thanks for the share and understand you not entering, very fair of you :)
Nice ! I will have to keep my eye out for those :)
Super blind is my middle name today ! Time to go and check them out. :cool:
