RockIt Cool for ryzen 9 5900x
  On 12/06/2021 at 20:41, Joe__Bishop said:
Good day all,
So I came across yesterday RockIt Cool.
They offer delid and relid cpu with changing Tim. I asked them to do liquid metal and use their custom custom ihs.
Anyone used them before or had experience in the past?
I have delidded with a rockit cool kit on 2 intel 9 series chips. Their product was sound, but I would save the money and do it yourself, it is very satisfying. I can help if you wish.
Deliding by itself is normal. I was wondering as well with regard to their copper ihs. I actually wanted to try to delid myself. But I don't have actual equipment  yet on hand. And that copper plate does look really interesting for extra couple of degrees
I understand, though if you delid, might as well run direct die.
  On 13/06/2021 at 04:09, Joe__Bishop said:
Is there a direct die transfer kit for am4?
I couldn't find anything in Google search in pictures only intel kits.
And I am not sure how even 5900x is, hence I don't want to Crack it by accident when I'll put a block on it.
That is of course always the risk. I think you can find a few video's on 9 series chips being delidded.
