G.Skill announces ultra-low latency DDR4-4000 memory kits
Performance PC memory and gaming peripherals specialist G.Skill has written to HEXUS with details about its latest "extreme low-latency, high-speed DDR4 memory kits". The firm has started to validate RGB-enabled Trident Z Royal, and classic Trident Z, DDR4-4000 32GB (8GB x4) memory kits with CL15-16-16-36 timings. We are told that the new 8GB x4 kits utilise select Samsung B-die ICs to achieve their fast clock speeds and "extreme low latencies". G.Skill points out that its previous best 4,000Mhz 32GB memory kits, for low latency, offered CL17 timings. You can see, for example, the F4-4000C17Q-32GTRS Trident Z Royal DDR4-4000MHz CL17-17-17-37 1.35V 32GB (8GB x4) kit here - it also sells CL18 kits of the same type/speed.
Source:https://hexus.net/tech/news/ram/135887-gskill-announces-ultra-low-latency-ddr4-4000-memory-kits/
Likely a nice pairing with the upcoming TR3 platform.
