liquid metal cooling loop
5 hours ago, Storm-Chaser said:
Just picked up the last of the gallium I need to fill the cooler.
I will be using a Z820 water cooler for this. It's easy to open the loop and it's a very low volume system, so I don't need a whole lot of gallium for this test.
I converted the gallium to Galinstan by adding a quantity of tin and indium. It should now be good down until about 40*F.
If this proves the concept I will be adding one of these to another system, it's very compact and should hold up fairly well to liquid metal.
Z820 cooler:
If proof of concept is a good result, I will try liquid metal with this:
shopping?q=tbn:ANd9GcRC3SzOH-uC6K-MK2TCd_O4EXje_dJ1S6PZ9iRc0GjNY2jLOE01q152ol0-P8N4nQPlgC_ofe3S7fbqWp0E36fTTa5ZaRwvbLJj9KQZAUOXJS-aDN_47v3ZNw
Wanted to comment yesterdays when i did my post about room temp and forgot about it. Happy too see project still underways 😀
