Tiny, 4-Inch Motherboard Can Run a Xeon W Workstation CPU
1.6k 943
Lately, we're seeing a slew of small systems with big processors, so we were weren't too surprised to see the Aaeon EPIC-TGH7 SBC reported in the pages of CNX Software. This four-inch (165 x 115mm) board has a list of compatible processors that begins with the Intel Celeron 6600HE, but which makes its way through the i-numbers to the mighty Xeon W 11865MRE.
Just looked at Passmark and 1 sample of the xeon processor did 23k.
Ryzen 5800x power on a 4 inch motherboard!
Text corrupted
That is awesome. Workstation power im a nice small package. However the issue that will trip up most wanting to create an SFF build, cooling potential. All well and good having a tiny mobo but ultimately, you will still need a larger cooler for those XEONS which would look limit how small you can go with the build.
1.6k 943
True but i was surprised they seem to be 11th gen intel but tdp is only 45w for some reason. Could use a aluminium case as a heatsink maybe.
Never heard of those processor before.
1.8k 2,025
Good chunk of copper like those slim Noctua coolers, or even a single 120mm AIO would probably be more than sufficient for cooling, at least to keep it at stock speeds.  I doubt the board allows overclocking anyway.  Probably don't even need a cooler THAT large really.  That "big" Xeon, the W-11865MRE with 4.7GHz boost is only a 45w part.  My small little aluminum wraith cooler does a fine job on 65w Ryzens.  45w TDP is getting into laptop cooling territory, my 2500u can draw twice that overclocked.
