EK releases Quantum Vector2 waterblocks for NVIDIA GeForce RTX 4080 Founders Edition
1.6k 943
EK-Quantum Vector² FE RTX 4080 D-RGB GPU Water Block
The EK-Quantum Vector² FE RTX 4080 is a liquid cooling solution that is actually a set of a Vector² series water block, a black-anodized aluminum backplate, and a custom-made single-slot PCIe bracket – all in a single package. As with the previous 30-series Vector² water blocks, the look is dominated by minimalistic straight lines and the backplate coming around the side of the GPU to cover the PCB in its entirety.
The Vector² cooling engine combines the jet plate with a 3D-machined Plexi insert to improve flow distribution and thermal performance. This cooling engine is based on an Open Split-Flow cooling engine design, which proved to be a superior solution for GPU water blocks. It is characterized by low hydraulic flow restriction, meaning it can be used with weaker water pumps or pumps running on low-speed settings and still achieve top performance. EK took great care to achieve a symmetrical flow domain by utilizing an internal bridge to secondary components. This was done to ensure the cooling of secondary components without sacrificing the flow distribution over the GPU core.
https://videocardz.com/press-release/ek-releases-quantum-vector2-waterblocks-for-nvidia-geforce-rtx-4080-founders-editionspacer.pngspacer.pngspacer.png
