Linux and macOS PCs hit by serious Sudo vulnerability
Andrew
Linux and macOS systems have been hit by a nasty little bug in the Sudo utility, although the good news is it has already been patched.
Sudo is a tool that provides a specified user permissions above their normal levels, including root (administrative) access, but by leveraging this security flaw, it’s possible a low-privileged user (or malware) could get unauthorized root access, and thus potentially wreak all sorts of havoc on the host system.
The fresh vulnerability (codenamed CVE-2019-18634) relates to Sudo incorrectly handling memory operations when the ‘pwfeedback’ option is enabled in the Sudoers configuration file, as The Hacker News reports. Essentially, when a password is requested, this security measure can be bypassed via a large input that triggers a buffer overflow.
