A Leaked EU Proposal Details Plans to Make Smartphone Battery Replacement Easier and Prevent E-Waste Build-up
Andrew
1.1k 548
Last month, the European Parliament voted for new rules to create a common charging standard for OEMs across the European Union. The idea was to cut down on electronic waste and enable consumers to make sustainable choices. To further the goal, the Parliament is now allegedly gearing up to present another proposal regarding smartphone battery replacement be made simpler.
