EK Nucleus AIO CR360 Dark Review Discussion
The latest entry in EK's treasure trove of winning products is the EK-Nucleus AIO CR360 DARK. They have introduced a host of enhancements over previous generations of their AIO offerings, including a new design of the CPU block and PWM pump. The new EK-Nucleus is available in both 240mm and 360mm variations, in white and black RGB, and the Dark (non-RGB) version that we are reviewing today.
Read the full review HERE
Release
Thank you, sir! Have a nice evening.
They are noted for having a focus on quality
OK, my personal opinions about EK aside, that was a good read and fantastic performance. Once again top notch formatting on the review too. I will need to learn your ways...
Thanks for the kind words brother. Have a nice Friday and a good weekend.
Lol you were the first person I thought of when I read the opening line about EK quality 😂
As much as I'm not into AIO coolers, it's hard to deny that they are a great option for the majority of people. Anything short of the top end CPUs don't really need the extra cooling potential of a custom loop. GPUs are an easier argument for custom loop because you typically cut your temps in half. Also these days the stock air coolers are getting comically large so slapping a block on is almost a necessity if you need to plug anything into any of the other PCIe slots.
Great read,well written review. My ONLY question is in regards to the OCCT testing, it seems strange that the custom loop and air cooled score the same while I believe the AIO score a touch lower? (or maybe higher,not sure how the ratings are figured in OCCT) I would have figured the air cooled to be the odd man out if there was going to be 1.  Edit: Also curious what EK considers "normal wear and tear" my previous AIO had 1 year or 3600 hours. (they figured a work day) It lasted me less then a year because I rarely turn my comp off.
3.5.3. Cases when EKWB AIO product Warranty does not Apply
The EKWB AIO product Warranty does not apply if the AIO product has been installed and/or used in a mfanner that does not comply with user instructions, or has been fitted on unsuitable materials.
  1. Normal wear and tear
  2. If the EKWB AIO product has been modified or repaired by personnel other than EKWB’s
  3. If the defect or damage has been caused by accident, lightning, or other electrical discharge, fresh or salt water immersion or spray (outside EKWB AIO product specifications); or exposure to environmental conditions for which the EKWB AIO product is not intended
  4. where the EKWB AIO product is damaged as a result of abuse, accident, or other causes beyond our reasonable control
Edited by schuck6566
Great review bro.
CPU: AMD Ryzen 5900X
MOTHERBOARD: Gigabyte X570 AORUS XTREME (rev. 1.2)
RAM: Corsair VENGEANCE LPX 4000MT (4x8)
GPU: ASROCK Formula RX 6900 XT
SSD/NVME: 2TB SSD x2
OPERATING SYSTEM: Dual Boot - Windows/Linux
OTHER: Custom Loop
CASE: Lian Li 011D XL
On 11/08/2023 at 14:14, RageSet said:
Great review bro.
Thanks, brother.
Thanks for the compliment, brother. I am not sure about your questions on the warranty issues. EKWB would need to answer. Normal wear and tear covers a wide gamut of things. One aspect is time and hours of use, but there are other aspects of wear and tear might not be time or use frequency dependent.
The benchmark scoring is a reflection of clock speed and the BIOS settings were the same with all three cooler tests, and the results were within a normal margin of error. If there were a hard thermal throttle that dropped clock speeds then there would be a lower score for the system that throttled due to overheating.
It bothered me that the custom loop didn't fare better, but it kind of makes sense. Where the AIO would have not done as well is under long term stress. I was not attempting to prove the custom loop better in the review. Had I run the stress test for longer we would have likely seen the water in the AIO get hotter and the temperatures increase, but the 5 minute stress test is already "more than normal" use scenario and my goal was to replicate the fringe of what a typical user would see in normal use.
After the review was completed it continued to bother me that the custom loop didn't have more distance between it and the AIO. It occurred to me that I had not cleaned the waterblock in a while, so I took it apart and found the fins in the jet plate had some crud in them. After cleaning it the custom loop was a couple of degrees cooler in the same test.
If the ambient temperate is the same, flow rate is sufficient and the contact adequate, allowing the AIO to efficiently remove heat from the CPU and whisk it away to the radiator at a rate equal to the custom loop the thermals will be the same until the water in the AIO gets hotter. The real benefits of the custom loop are greater coolant capacity (takes longer to get hot) and greater ability to keep the water closer to the ambient temperature for a longer period of time. Also, the ability to add more components in the loop, like GPU and RAM.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
