OpenRGB help; I'm noob at it
neurotix
Go to solution Solved by neurotix,
Hi all,
I want to permanently and finally get rid of Armoury Crate and Aura Creator. I've installed OpenRGB and plugins under Linux and after messing with it enough, got it to 1) do my vaporwave color pattern and 2) load on login and apply the profile.
However, compared to Asus Aura Creator, for some reason the lights are very pastel and dull. I can provide a screenshot if necessary. Basically its set to Magenta and Cyan and the proper RGB color (255/0/255) but for whatever reason the color isn't as deep and looks more pastel than Aura Creator by a significant amount.
Just looking for help with whatever setting for the effect plugin that will make the colors brighter and more accurate.
Thanks in advance.
  • Solution
Nevermind, I kind of figured this out on my own.
