AMD Ryzen 7 8700G desktop APU leak confirms 2.9 GHz Radeon 780M RDNA3 graphics
Leaked details reveal that the Ryzen 7 8700G APU will feature Radeon 780M graphics with 12 Compute Units, boasting a boost clock of 2.9 GHz. The lower thermal and power constraints in the desktop form factor should make it easy to increase the frequency above 3.0 GHz, though. Benchmark results, conducted using Geekbench OpenCL and Vulkan APIs, show 29244 and 35427 points, respectively. In comparison to Phoenix-based mobile APUs using the same specs, performance is within the margin of error. It should also easily be twice as fast as Ryzen 7 5700G “RX Vega 8” integrated graphics, but it is worth keeping in mind that synthetic benchmarks may not reflect gaming performance. For those, it’s best to wait for independent reviews to appear, which should hopefully happen soon.
https://videocardz.com/newz/amd-ryzen-7-8700g-desktop-apu-leak-confirms-2-9-ghz-radeon-780m-rdna3-graphics
