Upgrade From Vive Pro?
ENTERPRISE
Hey guys.
Not having been keeping up to date in the VR game but I have a friend that has the HTC Vive Pro and they wanted to know what the next worthwhile "step up" from that would be?
Thanks guys!
E
There aren't really any on the market that I would go for. A good step up in theory is the Apple Vision Pro, but instead of Apple letting it be compatible with Windows, they decided to not do that because they're Apple.
The only other VR headset I'd recommend is a Valve Index, but that's going to be a mostly sidegrade or downgrade in some aspects such as resolution.
I would agree. Not much to step up from but it could depend on their priorities. Vive Pro, Vision Pro, Quest 3, Index are all doing slightly different things. The only headset that pushes the boundaries for PC gaming and resolution is the Pimax. However, it's very expensive and is still bogged down by technical constraints (weight, cables etc.). If the users priorities are different, like comfort and portability, the Quest 3 would be a better bet (as a side grade).
WWW.EUROGAMER.NET
John Linneman reviews the Pimax Crystal, the 'highest clarity VR headset in the world'. What's it good for?
WWW.EUROGAMER.NET
Thanks for the suggestions so far guys, I am passing them on 🙂
