Defective RX 9070 XT card with pitted silicon surface runs extremely hot
Kaz
Igor's Lab received a defective PowerColor RX 9070 XT Hellhound from a reader who had purchased the card. While it had apparently passed quality control tests, Igor found a defective RDNA 4 die that resulted in unsustainable temperatures — which persisted even after re-pasting. According to the tech outlet, the culprit was "pronounced pitting," which can occur during the backgrinding process.
Igor's Lab does preface its report by noting that, for now, this is an isolated case and it cannot fully confirm what caused the damage to the die. It could be a single bad card, or perhaps a faulty production line may have resulted in a bad batch of dies. Either way, the extent of the problem isn't clear at present.
WWW.TOMSHARDWARE.COM
The culprit appears to be an improper backgrinding pass on the back of the silicon.
Just 1 so far, nothing to be alarmed about.
Had a laptop 1050ti that was pitted. From purchase it froze when gaming for hour. And when i opened it i saw that the die had a big crack/chip in it.  They rmaed my mainboard.
