Registered users can:聽
AMD Radeon "Navy Flounder" Features 40CU, 192-bit GDDR6 Memory
axipher
AMD uses offbeat codenames such as the "Great Horned Owl," "Sienna Cichlid" and "Navy Flounder" to identify sources of leaks internally. One such upcoming product, codenamed "Navy Flounder," is shaping up to be a possible successor to the RX 5500 XT, the company's 1080p segment-leading product. According to ROCm compute code fished out by stblr on Reddit, this GPU is configured with 40 compute units, a step up from 14 on the RX 5500 XT, and retains a 192-bit wide GDDR6 memory interface.
Assuming the RDNA2 compute unit on next-gen Radeon RX graphics processors has the same number of stream processors per CU, we're looking at 2,560 stream processors for the "Navy Flounder," compared to 80 on "Sienna Cichlid." The 192-bit wide memory interface allows a high degree of segmentation for AMD's product managers for graphics cards under the $250-mark.
