Cooler Master General Case Owners Club and Showcase
Supercrumpet
Cooler Master Cases
In an attempt to get some discussion and build sharing going, I'll make the first case club here on EHW. Since we're not super active yet, I feel like one general thread per case manufacturer would be appropriate, and as activity picks up, we can split each series into its own thread as necessary. I've added all of the series and cases that CM currently sells, in addition to some of the more popular older offerings. More older cases can be added as users with them post. Feel free to leave any feedback.
Cosmos Series
  Reveal hidden contents
HAF Series
MasterBox Series
MasterCase Series
N Series
Silencio Series
Owners
KSIMP88 - HAF 932 Advanced
Bastiaan_NL - HAF 932
Supercrumpet - HAF 932 Advanced, HAF XB, MasterCase MC500P, MasterBox Q300L
Cosmix48 - Cosmos II
damric - HAF 912, HAF XB
ENTERPRISE - HAF Stacker 915R, MasterCase Pro 5
Sir Beregond - MasterFrame 700
pioneerisloud - HAF 700, MasterBox TD500 Mesh V2
Edited by Supercrumpet
Reserved.
  On 11/11/2020 at 19:23, KSIMP88 said:
Still rocking my Cooler Master HAF 932 Advanced. I would love to see a refresh of this case, maybe even upgrades to buy? The front panel ports come off easily, so come on Cooler Master, build me a USB 3.1 panel! USB-C, etc
Hey, very nice. I had a 932 Advanced as my first case. In hindsight that was extremely silly, but I was blindly following another friend's recommendation given only my budget, and he was blindly following logicalincrements. I'll definitely be flushing out the HAF series in the OP even though it's pretty much all retired, and I'll post some pics of my old CM builds as well.
I still have the HAF 932, 360 rad in the top and 240 rad in the front.
Spray painted all the grey metal black, removed the hdd cage and the bottom of the 5.25" cage.
It's still one of my most favorite cases and it has seen a lot of different hardware :classic_biggrin:
I'll add the HAF series to the OP tomorrow probably, but here's my first build in my 932 Advanced. Still have the case tucked away in a closet, but I've been debating letting go of it as a free local pickup because frankly it's just taking up space, and I don't forsee myself ever needing it again.
These are some throwback photos to 2013 when I built my my first computer in a Cosmos II. It was a big and heavy 75lb (Empty Case is 47lbs) behemoth that I loved to death. (I still have the case and the original components, which still work.) I'll probably keep the thing forever, and may end up using it as a oversized media server as it has 13 drive bays. Cheers
Edited by Cosmix48
Wheyyy, welcome to the forum and thanks for posting. The Cosmos II is a case and a half.
Added almost every single HAF case I know of earlier today, the last one being the HAF XC, which never made it into production as far as I'm aware.
I just want to highlight the HAF Stacker again. Such a cool concept at a very approachable price for what it was. When they released it I really wanted one but I didn't have the need nor the funding for one. Now that I have both, it's long gone. Real shame it didn't catch on; would have been a cool trend with other mainstream case manufacturers.
Anyways I'll take the opportunity to show off the life of my HAF XB. Started out as a replacement for my 932 after I got sick of how massive it was, so naturally I needed to replace it with something that had a larger footprint.
Swapped out some parts for some upgrades and aesthetic improvements not too long after.
Much better. If I remember correctly, I swapped out everything except for the hard drives and the CPU. Everything else was sold or eventually repurposed.
Eventually, those internals were moved to my Riotoro CR1080 so it was a little more portable. The XB then housed my 24/7 folding rig, first with my two R9 Furys, then a 980 and a 960, chosen for the OCN Folding Team Competition. It still remains with the mismatching Nvidia cards, but those will probably get swapped out before too long.
Yes, I did color theme a dedicated folding rig with matching fans, RAM, and sleeved cable extensions. Yes, it's a problem.
Also, bonus group photo. Seems familiar @Cosmix48.
I'm guilty of this too, matching rgb and sleeved cables on every build :classic_laugh:
Here are a few pictures I found after searching my old backup drives.
I've had this case for over 10 years, and it has seen a lot of different hardware. I did a few small mods to it, in those years, but nothing special.
That's a sweet set of pictures, thanks for posting. After looking at your pictures and poking through my files to look for photos of my old setups over the past couple days, I kind of want to continue to hang onto my 932 as well, but I don't know what I'd ever do with it.
My first Cooler Master case was the HAF 912. It was a very good budget case, and crazy good airflow once all of the fan slots were filled.
I kept it maybe a year or two until I could get my hands on the HAF XB. When I saw the prototype demonstrations for that I knew I had to have it. You just cannot beat the horizontal motherboard layout. I have had this case for so long now that I can't remember when I bought it. 2012 maybe? It was almost as soon as it became available. I've run a ton of hardware builds through it and it is still what I use for MY RIG. The wife and the kids have the fancy glass towers with the RGB lightshow, but I'm not giving up my airflow box. I change out the fans every couple of years, and very often it needs a good cleaning. The only disappointment was when the drive bay pcb stopped working and I had to order a replacement pcb from overseas because apparantly there is no longer any CM support in the USA. I'd love to see this model get a modern update. Until then I'll just keep on with what I have. I'll post some pictures of it from the past decade's builds next time I'm here.
CPU: Ryzen 7 5800X
MOTHERBOARD: B550 PG Velocita
RAM: 4x8GB Ballistix
HAF XB tray makes it very easy to swap motherboards for benching/testing. Here's a few of the configurations I got to play around with in recent years. Some AM4 boards, Z170, A88X...
CPU: Ryzen 7 5800X
I still own my HAF Stacker 915R, though not in use right now. My last tower case however was the Mastercase Pro 5. Awesome case for the time with stunning airflow. Easy to carry as well with the clever handle grips worked into the design.
Good stuff guys!
I updated the OP at the end of last week, should include pretty much everything CM currently has on offer, plus some of the more popular cases from the good 'ol days.
I'm kind of annoyed at myself that I didn't get any proper pictures of this iteration of my main rig since I think it was my best, but I've already sold the 980 Ti and these are the two good pictures I have of the MC500P build. Pics are from last year; I really really like how that front "panel" turned out when I just left it open and cut out that support beam for the mesh cover, looks really nice but it's pretty impractical. Whatever, those are my priorities haha.
Last week I also received my Q300L, so keep an eye out for that. Will hopefully be building/rebuilding most of that over the next week or two.
I still hate myself for getting rid of my ATCS 840 case. It also had a motherboard tray, something that should be used on more of the high-end cases.
That's a nice setup!
I know how you feel about taking not enough pics. I had so many builds, cool setups and things like that but I only have a few pictures from them.
Looking forward to the Q300L build, looks like a nice compact case to build in :classic_smile:
Good stuff guys!
I did enjoy the rubber cable grommets in the bottom of the CM cases at the time. Made cable management nice and easy!
Q300L update, stuff isn't fitting quite the way I expected it to, so I'm taking the stupid route.
Also this is my first time delving into RGB stuff, I'm having a great time with the cabling.
Sounds like a great time, good luck making it work!
I know how you feel with the RGB cabling, RGB looks cool but it's lot of cables to mess with :classic_laugh:
It was indeed just a simple case of wiggling the RAM, as my friends call it. Remove all sticks, re-insert one at a time, no issues. Missing some fan splitters that should show up today, but I was able to get enough fans running for it to operate at acceptable temps while folding, so we're back up to normal. Will post more pics when it's all set up tonight or tomorrow night.
"Will post more pics when it's all set up tonight or tomorrow night," he lied. Whoops.
Got some more bits and bobs for the Q300L build in the mail a couple days ago, so hopefully when I got some time this weekend I'll re-cable some things and take a before and after.
Other plans I had for tonight fell through so I went ahead and added the new stuff tonight, including a fan controller, fan grilles, and a kayak handle. Quite pleased with the outcome.
The whites of the fans, GPU, and RAM don't match in person but they look great in pictures. Only thing I'm waiting for at this point is sleeved cables.
