Gigabyte Juices Up GeForce RTX 3080 With a Third 8-pin PCIe Connector
ENTERPRISE
Gigabyte (via momomo_us) has apparently revised the company's Aorus GeForce RTX 3080 Master 10G (GV-N3080AORUS M-10GD) with a new power layout. The Revision 2.0 board, the spitting image of the prior revision, sports a third 8-pin PCIe power connector.
The GeForce RTX 3080, rated for 320W, makes do with a pair of 8-pin PCIe power connectors. Bearing in mind that the PCIe x16 slot provides 75W, a setup with two 8-pin PCIe power connectors provides power delivery up to 375W, more than sufficient for a GeForce RTX 3080. However, custom models with high factory overclocks typically sip more power, explaining the dependency on more PCIe power connectors.
https://www.tomshardware.com/uk/news/gigabyte-juices-up-aorus-geforce-rtx-3080-master-third-8-pin-pcie-connector
