ASUS GeForce RTX 3060 ULTRA Photo Leaks, yes ULTRA
ENTERPRISE
That's right, not 3060, 3060 SUPER but 3060 ULTRA. If this is true, then NVIDIA might position yet another 3060 SLU into the market, positioning itself in between 3060 Ti and 3070 presumably.
If this product is released, it might be because of the pending series Radeon RX 6700 release of course. The card would use the now familiar 8 nm GA104 GPU, used in the RTX 3060 Ti and RTX 3070; but with a different shader core-configuration and likely 12 GB of GDDR6. At wccftech a box photo of the custom RTX 3060 Ultra card was spotted as well, the ASUS TUF Gaming. Predicted pricing; USD $449.
Source: https://www.guru3d.com/news-story/asus-geforce-rtx-3060-ultra-photo-leaksyes-ultra.html
Well if i cant get my hand on a 3080 or 6800xt maybe that would be an option if it has 12gb vram
Well apparently there is a 3060 being released with 12Gb of VRAM.
Yea but i want something faster than the 3060ti. Since i had a 5700xt and sold it at a loss. ?
I feel you. I want a new GPU but the stock seemingly does not exist :(. Currently on a 1070...which fortunately is still holding it's own.
Had one loved it rock stable.
Cant says the same for my 5700xt for some reason fan speed worked intermittently except that no crash or issue.
This is the thing, I always see both sides when it comes to AMD GPU's, but taking into account the good and bad I hear it's virtually 50/50. So im usually hesitant about going over to the red team.
