Intel pits Xe against Big Navi using 7nm 'enhanced' process for its gaming GPU
ENTERPRISE
Intel has chosen a newly enhanced version of TSMC's 7nm production process for its upcoming Xe-based DG2 gaming card. So, says Reuters in a report which pegs the release date for the new GPU as later this year or early 2022.
Source:https://www-pcgamer-com.cdn.ampproject.org/v/s/www.pcgamer.com/uk/amp/intel-dg2-tsmc-7nm-process-node/?amp_js_v=a6&amp_gsa=1&usqp=mq331AQFKAGwASA%3D#csi=0&referrer=https%3A%2F%2Fwww.google.com&amp_tf=From%20%251%24s&ampshare=https%3A%2F%2Fwww.pcgamer.com%2Fuk%2Fintel-dg2-tsmc-7nm-process-node%2F
Yea new gpu! Dance Dancing GIF by The Dude Perfect Show
One thing is for sure, TSMC will be real busy for a while !
I am also wondering whether Intel will actually release a 2-tile Xe consumer GPU in 2021, though the 4-tile is unlikely for consumers this year, IMO. Below is a little tile collage > ? of recent "news" stories - best taken in with salt - on this complementing the original post above...and also per earlier threads on Intel Xe, it would be sooooo nice if there will be a 3rd real competitor for higher-end GPUs. Hopefully, it won't be an 'out-of-stock, out-of-stock, out-of-stock' launch...
TSMC this year certainly are not looking for work.
It would be great if Intel can be a true competitor to try and bring prices back to a better level....not to mention stock with a GPU you can actually get your hands on !
2 minutes ago, Chiraq said:
The more the merrier. Intel gpu's should kick ass. Would be fun running an Intel gpu with my AMD cpu. LOL
So when are Cyrix launching a gpu? :D
Speaking of Cyrix, let's get some of that 3DFX Voodoo series rebooted.
