Unable to Add Attachment to PM or Post and Kicked Out of Editor
--Update--
I also cannot add the guide to a post.  Blocked with the same screen, but upon returning to the thread the content is still in the editor.
While attempting to attach a .txt file in a PM, the attacment errored out with a -200 error code forcing me to close the message and then open it again to get rid of the failed attachment.  This worked without issue a few days ago.
After the attachment failed I than pasted the text into the editor, and after spending quite some time reformatting, I was greeted with the below screen after hitting send.
Next I fired up a different browser, tried pasting the text into a code block, but I got hit with the same screen, just with a different Cloud Flare Ray ID: 69c425165eddfeaa
OS: Arch Linux
Browsers: Chromium and Firefox
Extensions: Disabled while trying to send the PM
Edited by tictoc
  • tictoc changed the title to Unable to Add Attachment to PM or Post and Kicked Out of Editor
Thanks for the report. We will take a look into why this is triggering our security and get back to you.
@tictoc
Please could you try again ?
  On 11/10/2021 at 18:39, tictoc said:
I certainly can.  It won't be until later this afternoon, but I'll give it a go and let you know the results.
No problems 🙂
@tictoc any further issues with this ?
Sorry I forgot to report back.  I did try it again, but the result was more or less the same.  I will give it another test in this post.
*Test 1 with Firefox* With the text pasted into a code block in a spoiler, I was sent to a captcha page, completed the captcha, and then it just kicked me back without submitting the reply.  All of the content was still in the editor.
*Test 2 with Firefox* Attaching the .txt file to this post resulted in the same -200 error
*Test 3 with Chromium* Attaching the file failed with the -200 error.  Pasting the text into a code block did work after completing a captcha.
  Reveal hidden contents
Edited by tictoc
Thanks for the feedback bud. Could you re-screenshot the error ? Just so we can reference log files our end and investigate further.
Thanks for info, let me speak with our server guy 🙂
@tictoc
So after looking into it, it is the contents of the txt file which our security does not like, so in order to get around this simply archive the file and upload 🙂
  On 25/10/2021 at 16:43, ENTERPRISE said:
@tictoc
Evil Linux h4x0|2 😆
Thanks for looking into it E, and archiving similar files is an easy workaround. 👍
  On 25/10/2021 at 17:27, tictoc said:
Evil Linux h4x0|2 😆
Darn Linux users ruining it for everyone 😛  No problems. Most txt uploads will work but once assume it is the commands etc inside the txt file the firewall simply does not like, I mean it makes sense.
