New MacBook Pro chips deliver desktop performance with better power efficiency
The M1 Pro is a 10-core chip that features increased memory bandwidth and interfaces, and AnandTech notes that it's been designed from the ground up to feature more performance for professional users. The M1 Max is "essentially identical," except for the massive 32-core GPU.
AnandTech highlighted the "huge memory bandwidth" of the new chips, as also pointed out the fact that both chips are well ahead of the competition in terms of power draw and efficiency.
As far as CPU performance, AnandTech notes that Apple hasn't talked much about increased CPU performance, which is likely because not much has changed from the M1. Despite that, the M1 Max still lands as the top-performing laptop chips in AnandTech's ranking. It ranked below the AMD Risen 5950X as far as best overall CPU, but by a close margin.
APPLEINSIDER.COM
Apple's new M1 Pro and M1 Max chips in the <a...
I Interesting to watch this play out. Cool that Apple made a good chip but it seems sorta wasted since there isn't much to do with it on an apple device. Still, interesting to see the state of ARM SoC tech.
  • 2 years later...
I'm not sure why this old thread popped up on the side, but I can tell you this.
At work my old 2019 Intel MacBook which I would describe as a complete piece of garbage with PC laptop levels of bad battery life was replaced with an M1 Pro based MacBook Pro in December and I love this laptop. I literally used it for an 8 hour day and the battery had only gone down to 60%. My old Intel one, even when new, barely lasted a couple hours before having to find a plug. I move around the house a lot for where I work (I work from home) and sometimes I work outside the house, so it's nice not having to be tied down to a cord.
In terms of calling it "wasted"...I'd say that's not really true. I work for a fortune 10 enterprise and our department uses nothing but Macbooks to code/develop, etc. They are perfectly functional machines that everyone here would say work much better than their previous Intel i9 based Macbooks which would just immediately throttle and performed worse than i7 based models. Of course that was just Apple's stupid design with no real thermal solution for a hot chip like an i9. The M1's are definitely better that way.
If you say well they aren't gaming laptops, well...yeah. It's Apple.
Anyway, my team are not particularly power users by any stretch like the development teams are, i.e. I'm not really running apps as most of what I work on is in Outlook, Teams, web Office 365, or web based CI/CD tools. Given that though, it is nice running all day on battery and not having to even look at the icon to see if I am running out of juice.
EDIT: And given that, my job would obviously be perfectly fine on a Windows machine too. I don't really care which. The iOS app devs probably like the Macs though would be my guess.
After browsing for month for good battery life.
It either lenovo Z13, Chromebook or a Macbook if you want battery life.
The only one with a decent price ratio is the Macbook.
Intel are horrendous and amd based device are not that much better.
