Data Rack Fans ?
ENTERPRISE
Go to solution Solved by Diffident,
Hey guys,
So I have a new data rack cabinet with a fan location at the top where presumably I can fit a fan. However for the life of me I cannot find somewhere that just sells the single fans on like USB for the power, or UK plug.
Any ideas ?
Thanks,
E
  • Solution
  On 05/11/2021 at 23:25, ENTERPRISE said:
Hey guys,
Any ideas ?
Thanks,
E
Is this what you're looking for?  I use these for my RPI's.
Fans
They also make 120mm fans.
Fans
Yeah those. I actually had a derp moment as I realised I can get a 3Pin to USB Cable and use any of my fans I have hanging around !
