Registered users can:聽
Linksys EA8500 Not Running At B-Only Speeds When Specifying B-Only Mode?
I tried setting Mixed mode then B Only mode & it didn't fix it & I tried restarting the router to no avail.聽 It's supposed to operate at 11Mbps network speed, rather than 130.0Mbps & beyond.聽 I'm trying to limit the Guest wifi only.聽 Which I have done so successfully prior to this new configuration.聽 It's a really simple configuration though, the ISP source is AT&T hotspot & the EA8500 is in Wireless Repeater mode connected to the more reliable 2.4Ghz wifi band of the AT&T hotspot.聽 Before I had it in Wireless repeater mode but connected to the 5Ghz band of the hotspot & it was dropping connections a lot.聽 Now it's very stable on the 2.4Ghz band but it's way too fast, it's not limiting the speed like it's supposed to.
Edited by HeyItsChris
try on b/g only or g only and see if it slows it down to the 52Mbps speed at least. If it does,then it may just be a glitch in the programing or listing order.You'd think that the b only option would be BEFORE the n only option anyway.
@schuck6566I fixed it by using the 5ghz band of the hotspot internet source as the primary Wireless Repeater mode band of the Linksys Smart Wifi.聽 Then it works by forcing the 2.4Ghz band of the Linksys Smart Wifi to Wireless B-mode only (11Mbps).聽 I hope that makes sense.聽 Since if I used the 2.4Ghz band of the source internet AT&T hotspot as the Wireless Repeater, it forces the 2.4Ghz band of the Linksys Smart Wifi to Full Speed 300Mbps or so or N 2.4Ghz.
