Registered users can:聽
How To Fix Tom Clancy's Rainbow Six Vegas PC Xbox One Controller?
I configured it up according to what everyone said online in the聽PCKellerJoysticks.ini file & it's still not working on my new Bluetooth XBOX One Controller & older non-Bluetooth Xbox One Controller over a wired USB connection.
Does the controller work on other games in general and its only Rainbow Six you are having issues with ?
拢3000
拢3000
@ENTERPRISEThanks for the reply bro.聽 Also, yes it works in most other games which say its compatible with a controller.聽 It's just I don't know some details about my specific controller(s), like these values...
[Joystick0]
ProductName=XBox Controller HID Minidriver, XID
VendorID=2341
ProductID=5768
PCKellerJoysticks.zip
*Update*
Still not working
Would any of this data help get it working?
Field聽聽 聽Value
Device Properties聽聽 聽
Driver Description聽聽 聽XINPUT compatible HID device
Driver Date聽聽 聽6/4/2021
Driver Version聽聽 聽10.0.22000.1
Driver Provider聽聽 聽Microsoft
INF File聽聽 聽xinputhid.inf
INF Section聽聽 聽GIP_Hid
Hardware ID聽聽 聽HID\VID_045E&PID_02FF&IG_00
聽聽 聽
HID Device Properties聽聽 聽
Product聽聽 聽Controller (Xbox One For Windows)
Device ID聽聽 聽045E-02FF
Usage聽聽 聽0005h
Usage Page聽聽 聽0001h
Input Report Byte Length聽聽 聽16
Output Report Byte Length聽聽 聽0
Feature Report Byte Length聽聽 聽0
This is from the .ini file
[Joystick0]
VendorID=2341
ProductID=5768
Joy1=XboxTypeS_A
Joy2=XboxTypeS_B
Joy3=XboxTypeS_X
Joy4=XboxTypeS_Y
Joy5=XboxTypeS_RightShoulder
Joy6=XboxTypeS_LeftShoulder
Joy7=XboxTypeS_LeftThumbstick
Joy8=XboxTypeS_RightThumbstick
Joy9=XboxTypeS_Start
Joy10=XboxTypeS_Back
Joy11=
Joy12=
Joy13=
Joy14=
Joy15=
Joy16=
Axis_X=XboxTypeS_LeftX
Axis_Y=XboxTypeS_LeftY
Axis_Z=XboxTypeS_RightX
Axis_Rotation_X=
Axis_Rotation_Y=
Axis_Rotation_Z=XboxTypeS_RightY
Slider_0=XboxTypeS_RightTrigger
Slider_1=XboxTypeS_LeftTrigger
DPadUp=XboxTypeS_DPad_Up
DPadDown=XboxTypeS_DPad_Down
DPadLeft=XboxTypeS_DPad_Left
DPadRight=XboxTypeS_DPad_Right
Should I simply convert the hex Vendor ID & Product ID from the Device ID to decimal?聽 Like this...
According to converting them it should look like this
[Joystick0]
ProductName=XINPUT compatible HID device
VendorID=1118
ProductID=767
UseXInput=true
Joy1=XboxTypeS_A
Joy2=XboxTypeS_B
Joy3=XboxTypeS_X
Joy4=XboxTypeS_Y
Joy11=
Joy12=
Joy13=
Joy14=
Joy15=
Joy16=
Axis_Rotation_X=
Axis_Rotation_Y=
Edited by HeyItsChris
Ok so the game does not have native support for the XBOX One controller on PC by the looks of things.
I am guessing this is what you have already tried ?聽
STEAMCOMMUNITY.COM
Doesn't work with an Xbox One controller, even with the Xbox 360 controller option turned on.
Having not really used the XBOX controllers on PC, I have no real insight into how to go about fixing this, less knowing that the game does not officially support it.聽
Not sure if you tried this for a Wired controller :聽
STEAMCOMMUNITY.COM
I'm posting this after two hours of browzing threads and trying to find my outdated controller's IDs. This should work for any wired gamepad. Open the file Steam>SteamApps>common>Rainbow Six Vegas...
I am sure some/all of these you have found already. I would also be inclined on focusing on getting the wired one working first, just to remove the additional factor of wireless.聽
拢3000
拢3000
@ENTERPRISE聽Thanks bro.聽 I tried my actual Product ID & Vendor ID & I tried other IDs & they didn't work on Vegas 1.聽 I'll keep trying though.
*Update*
I got it working but by using this instead.
GITHUB.COM
Primary repository for the x360ce library, front-end and tools. - x360ce/x360ce
