Ddr4 in canada? I need 3600 c14 and it out of stock
Hello wondering if anyone had an idea where i can get some ram.
I got 2x16gb Oloy 3600 c14-14-14
And i want to add 2x16 but it out of stock everywhere.
Maybe some 3200 c14 or 3600 c16 from another brand would be an option but am not too sure how z690 motherboard are open to mixing ram and manually setting them.
Maybe am better getting 64gb on my laptop and use it as a server.
37 minutes ago, Avacado said:
Please don't buy 3200 DDR4. 3600 is the standard for DDR4, if you buy 3200, you are already behind the curve.
I know 😞
Well i think am gonna get some 2666 2x32gb for my laptop anyways it almost the same price as 2x16 3600 c16
Could run some server from it and upgrade one days to a new gaming laptop if i ever have to move!
Gonna play with that oloy if i can do 3800 c14 with tighter sub timing would be nice
1 hour ago, Avacado said:
Oloy makes some decent kits. I had some Oloy DDR4.
Il report back the result.
Now am beating on my 6800xt i had issue with it and i think the silent bios was the problem.
FYI, I bought multiple 'fast' DDR4 kits here in Canada at Memoryexpress, including 4x8 4000/CL15 Sammy-B-die last year. These days, that single-rank type is hard to find, but there are multiple 2x 8 and 2x 16 kits for 4000 CL/16 at Memoryexpress available.
Ohhh forgot about that seller! I was looking at canada computer and newegg + amazon.
Thank you 😄
Feel kinda dumb since i dream about a 13900k and 32gb with a 13900k kinda sound weak lol
Finally found this from newegg.ca but from usa. Kinda ways too expensive but well my fault for getting ddr4 instead of ddr5.
Now i wonder if am going to have to run gear 2
