12700k + 4x16gb dual rank samsung booted once at 3600 c14 gear 1 now only gear 2
Hello wondering if anyone as any trick or can help me out. Just got a second set of ram one is a gskill and one is a oloy both are dual rank samsung by cpu z.
3600 cl14 - 14 - 14 1.45v for both.
My setup:
12700k
MSI Z690A ddr4
2x16 oloy + 2x16 Gskill
First boot with the second set failed then i enabled XMP and tried many time to boot then got it to boot at 3600 gear 1 at 1.4v vccsa and 1.5v ram all the rest is stock.
Tried some occt ram and other mem app and everything was running fine even rebooted without issue then i tried to reboot and lower vccsa and it never wanted to boot again at gear 1 even with vccsa at 1.45 and ram at 1.52.
 I can boot at default xmp gear 2 without any issue for some reason.  But can't even boot at 3000mhz cl14 - 14 -14 at 1.40v vccsa and 1.5v ram
Just looking the most performance for gaming and my BOINC / Folding@home task.
Kinda lost here seem like a software issue or maybe the memory learning option i can't understand what it does.
Thank you
Fixed!!!
Running XMP at 1.55v ram and 1.4 vccsa and gear 2 to boot then rebooting and switching to gear 1 work most of the time.
Memory learning seem to be the issue. Maybe memory try it can help.
Running at gear 1 without issue
glad got that figured out.  I'm still playing around with mine to see if I can get 3800mhz to boot... it'll post, but it's not stable, even in bios.  I haven't tried the "safe" timings yet from the dram calculator, but the way it acts... I kinda think it's the infinity fabric losing stability... IDK, new to this level or ram speed.
Not stable at the end. Just started some Sidock work instead of rosetta and it started failing gpu and cpu render.
Will go back to gear 2 at stock vccsa and ram voltage. Maybe i can overclock it further but i think the imc is going insane with those 4 stick
11 hours ago, Minotaurtoo said:
well drat... that's ram for you.  I found out that my board apparently has a memory frequency hole at 3800mhz.  I looked at the memory support page for it and the supported memory goes from 3733 to 3866. not one kit of 3800 listed.
Seem like they have a hard time making those work.
I need to do more testing but am lazy for now gear 2 seem to run at stock xmp. DDR4 was out for so long and they never figured how to make 4 stick stable at high clock 😐
I managed to get a good boot on 3733 and a not so stable boot on 4000 so yeah, must be a hole in what this board can handle... but strangely I have to decouple the memory controller from the IF to do it for either with leads to lower performance... so far 3600 with tight timings is king... I think it's just a board limitation, might try swapping to the other memory slots to see if they work better... board traces may be crossing over or leaking.  As for your 4 stick issue, the most I was ever able to get out of 4 sticks stable was 3200 in gear 1... never tried gear 2 to see if that would help.
Was not able to really play with my setting since it do not even boot at stock xmp at 3000mhz at gear 1 for some reason.
Some board are better than other  am currently working on a 990fx with 2400 ddr3 ram and that thing do not even boot at higher than 800mhz the ram is probably shot got it used or the motherboard is not liking it.
Kinda fun playing with ram since we can't really do anything with newer cpu and gpu!
That why i got that 990fx and some old amd cpu to have some overclocking fun.
Just ain't got the time sadly to do that.
  • 8 months later...
Update:
Now with 13900k cpu and i sold my gskill set of 2x16gb and got myself a set of oloy with exact same spec but 2x8gb.
Run stable at xmp 2x16 + 2x8gb for 48gb at 3600 cl14.
Will update on overclocking result
