May someone offer help finding drivers for these devices on AMD Ryzen 5 3550H Mini PC?
HeyItsChris
Multimedia Controller
AMD K17.1 - Audio Processor
PCI\VEN_1022&DEV_15E2&SUBSYS_15E21022&REV_00
PCI Device
AMD K17.1 - 10Gbe Controller Port 0
PCI\VEN_1022&DEV_15E6&SUBSYS_15E41022&REV_00
Edited by HeyItsChris
  • HeyItsChris changed the title to May someone offer help finding drivers for these devices on AMD Ryzen 5 3550H Mini PC?
I'm reading conflicting reports on those, although I could be searching incorrectly too......
Try installing the official AMD chipset driver first of all, for that particular mobo.  From there, try to manually install the drivers, click browse, and point it to the installation directory of the AMD chipset drivers (for both).  You might also check on the manufacturer's website for that particular mini PC too, they should have the drivers needed available for download there.
If that doesn't work, you can always do a quick search of the PCI\VEN_xxxxx string.  I've usually had pretty good luck finding unknown drivers that way.
Good luck!
