Can anyone find proof a 32GB module will work on a AMD Ryzen 5 2500U?
The motherboard I wanna test this on is the Lenovo Ideapad 330S-15ARR because it has only 1 slot and 4gb onboard, so i'd like to see if it would support 36 gigabytes of ram in total.
LenovoIdeapad330S-15ARRmotherboardwithryzen2500uandradeon5402gbgraphicschip.thumb.jpg.28e9f7f12285c370af147869cd18afef.jpg
It will probably work issue is it will be single channel.
2 hours ago, HeyItsChris said:
That would be amazing to line up 36gb on a 2500u laptop with radeon 540 graphics chip.
Ran 12gb of ram on a intel that supported 16gb but mobo was rated for 8gb once.  It worked but i had some stability issue with the vrm overheating. Put a i7 in a low end pentium notebook haha
Saw 16GB sodimm worked from a google search to get max 20GB, but no idea about 32GB sodimm.
Check the CPU specifications. The CPU will detail its max supported RAM. That can also be a good indication.
Google seems to suggest max memory support of 32GB in dual channel, so since you only have a single sodimm slot (single channel), I think 16GB is probably the max.
I found this & it looks promising.
WWW.COMPURAM.BIZ
Available RAM Upgrades Overview | Ideapad 330 300-Series ✭ with CompuRAM max up to 36GB ➚
Edited by HeyItsChris
WWW.COMPURAM.BIZ
Can always try and send back if it doesn't work perhaps.
