Thermalright's HR10 Pro SSD Cooler: The Perfect Solution for Gen5 SSDs!
1.7k 948
Thermalright has revealed the HR10 2280 PRO, a new and improved version of its cooling solution for next-gen SSDs. The updated design features four 5mm heatpipes and a 30x30x10mm 12V fan, which can operate at 3500 to 6000 RPM but may produce some noise when approaching the thermal limit. The SSD radiator is tailored for NVMe SSDs in 2280 form factor and can support both one and dual-sided storage. With dimensions of 90.3×23.7×43.8 mm, the HR10 2280 PRO is capable of dissipating up to 45W of power.
https://videocardz.com/newz/thermalright-hr10-pro-ssd-cooler-is-ready-for-gen5-ssds
http://www.thermalright.com/product/hr-10-2280-pro/
Looks like a nice cooler.
I forsee issues with motherboard "armor" however.
CPU: AMD Ryzen 9 7950x
SSD/NVME 3: SK Hynic P41 2TB
Just now, iamjanco said:
Check that ✅
There's also this: Rated Speed:3500 – 6500 RPM±10% (MAX). Should make for a nice, high-pitched whine 😉
For anyone that wants the server-level sound without the hassle, just grab this!
