|BUILD LOG|| Corsair 1000D | " [email protected] CANCER "
Posted (edited)
Welcome to my build log! This is not my first build, but it is the first time that I’ve done a build log on Extremehw
**** CAUTION WILL BE ALLOT OF MODDING / PICTURES****
Scope of Project - Estimated Completion:
This is going to be a long-term project for me. I have always been one to “quick tear it down, do the upgrade, and quick get it back together I need my rig”, I’m sure many of you can relate to that. My current machine is serving me well, so now I can take my time on this one without having to rush anything. I want to enjoy the ride!
I estimate this to be completed no sooner than the end of this year 2023, or more likely early 2024. When it’s done it’s done. I am very busy at times, so there might be several weeks or even several months at a time when little may get done. Just hang in there with me and you’ll be glad you did.
Plus the hardware I plan to put in this build will not be available until the second half of this year. I have lots to do meanwhile. I see so many people buy all their hardware first, and then by the time they are done with the build the hardware is a generation or two old. By the time I buy the hardware for this build, the case, radiators, fans, most of the water cooling, plumbing and wiring will all be done. It will be a complete chassis just waiting for some awesome hardware.
Naming:
Some who may know me from OCN or personally know I lost my mother to Lung cancer; it was the reason why I got into [email protected]. Well at the beginning of this year I lost my mother-in-law to pancreatic cancer. So needless to say, this build will be a tribute to both my mothers and the name speaks for itself!
Colors:
WHITE|PURPLE
 Projected Hardware at start of build log
Case: Corsair 1000D
Motherboard: MSI MEG X670E ACE AM5
CPU: AMD Ryzen 9 7950X3D
Memory: CORSAIR Dominator Platinum RGB 64GB (4 x 16GB) DDR5 5600mhz
GPU: RTX 4090
PSU:  EVGA Supernova 1600w
SSD:
SSD:
Cooling:
Radiators: 4x EK-Quantum Surface X480M |58mm|
Fans: x34 Lian-Li Uni SL 120mm
Pumps: 2X D5 655
Reservoirs: 2x EK-Quantum Kinetic FLT 240 D5
Fittings: Ek quantum torque |NICKEL|
Tubing: EK 16MM PETG
Water Blocks: |CPU-EK-Quantum Velocity²|
Modifications I plan On Doing
- Custom PSU Shroud
- Custom Motherboard Tray
- Custom Top + Front Radiator Mounts
- Glass Etching
- Sleeving
- Fan Designs
- Paint ( Motherboard Heatsinks, Case ??
- Acrylic RGB Signs / 7" Screens
The Ruff Idea / Brainstorming
** Sorry I am no graphic designer 🤣 **
Edited by REPUBLICOFGAMER
Looking forward to seeing more 🙂
MOTHERBOARD: ASRock X570 Aqua
£200
CPU: AMD RX-427BB
NETWORK: Intel I350 -T4
CASE: HP Thin Client T730
SSD/NVME: Intel 512GB 670p NVMe
SSD/NVME 2: Samsung 1TB 980 NVMe
SSD/NVME 3: 2x Seagate FireCuda 1TB SSD's
Excited to see this.
CPU: Ryzen 9 5950x
MOTHERBOARD: X470 Taichi
RAM: 4x8GB VIPER STEEL
PSU: LEADEX III 850W
CASE: HAF XB
SSD/NVME: Silicon Power A80 1TB
SSD/NVME 2: Silicon Power A80 1TB
Cheap
CPU: Ryzen 7 5800x
RAM: Crucial Ballistix 4x8GB
GPU: Quadro M4000
GPU 2: Quadro M4000
PSU: SUPERNOVA P5 650W
SSD/NVME: Samsung PM981 256GB
Cheap
CPU: Ryzen 5 5600G
MOTHERBOARD: ASRock B450M Pro4
PSU: LEADEX III 650W
CPU COOLER: TPC 612
OPERATING SYSTEM: Windows 10 Pro
GPU: Radeon Instinct MI25
Premium Platinum
585 319
Posted (edited)
Yeah, this will be pretty insane. 😉
I have a similar build already, however mine is not watercooled with four 480mm rads (wish it were). I suffer from pain issues, so am not able to build a loop or do the maintenance on it.
You'll be happy with the 7950x3d and RTX 4090, however.
$5500
RAM: G.skill Flare X 6200MHz 30-36-36-36-108 subtimings tuned
MOTHERBOARD: Asus ROG Strix X670-E Gaming
SSD/NVME: Samsung 970 Evo 512GB
CPU COOLER: Corsair H150i RGB Pro XT
GPU: MSI RTX 3060 Ventus
CASE: anidees Ai Crystal Cube
PSU: OCZ ModXStream 550w
CPU: FX-8350 lapped stock 4GHz
MOTHERBOARD: ASUS Crosshair V Formula
RAM: G.skill TridentZ DDR3 2400MHz 10-12-12-31
KEYBOARD: Rosewill K85
Love the title, looking forward to it.
CPU: Intel Core i7-4790k
GPU: ASUS GTX 980 Strix
RAM: Corsair 32GB DDR3-2400
MOTHERBOARD: ASUS Z97 Deluxe
SSD/NVME: Crucial M550 512GB
HDD: 2x WD Black 3TB
PSU: Corsair AX750
CASE: Lian Li O11 Dynamic
Shaping up to be a pretty sweet rig!
CPU: 5900X + Optimus block
MOTHERBOARD: MSI X570 Ace
RAM: 32GB Oloy Blade 3600CL14
SSD/NVME: 1TB SN750 Black
SSD/NVME 2: 1TB SN750 Black
CPU: Delidded i9-10850k
MOTHERBOARD: z490i Aorus Ultra
RAM: T-Force Xtreem 3600cl14
GPU: MSI RTX 2080
CPU: 7700X
MOTHERBOARD: Strix B650E-I
RAM: G.Skill Flare X5 6000
GPU: EVGA 1080ti
