EXTREMEHW Foldathon July 22-23rd 00:00 UTC
Weather has been unseasonably cool in the Northern Midwest for like a week. Around 75f-80f tops. This is strange for mid to late July, usually we are around 85-95f with high humidity. I bet we'll have a really hot August instead.
A little late on the start, but at least one GPU will be folding for the FaT.
--EDIT--
Fired up F@H on the outgoing 2080 Super one last time. 😀
| NVIDIA-SMI 535.86.05              Driver Version: 535.86.05    CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 2080 ...    On  | 00000000:09:00.0  On |                  N/A |
|  0%   52C    P2             203W / 292W |    547MiB /  8192MiB |     97%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A       638      G   /usr/lib/Xorg                                32MiB |
|    0   N/A  N/A       761      C   ...it/22-0.0.20/Core_22.fah/FahCore_22      510MiB |
I did ease back the clocks a bit for its last hurrah on my bench. 😉
nvidia-settings -c :0 -a '[gpu:0]/GPUGraphicsClockOffset[4]=-120'
Edited by tictoc
in Jeff_Petovello
OPERATING SYSTEM: Windows 11 Professional Version 24H2
CPU: AMD Ryzen 9 5950x
MOTHERBOARD: Asus ROG Strix X570-E Gaming
RAM: Corsair Vengeance RGB Pro 3600Mhz 32GB
GPU: Asus ROG Strix Gaming 6750 XT OC
CASE: Corsair Crystal Series 680x RGB
MONITOR: BenQ XL2730Z 27.0" 2560x1440 144 Hz
AUDIO: Sennheiser HD599
OPERATING SYSTEM: pfSense Plus 24.11
CPU: Intel(R) Xeon(R) CPU E3-1225 v5
RAM: Micron DDR3 16GB
NETWORK: Intel 82580EB QuadPort Gigabit Ethernet Controller
Damn it sucks being old thought this was Friday. Gonna fire, key word its hot here, up a comp. Maybe 2 if I can throw it in another room.
PSU: Thermaltake 1350
GPU: 6800 XT
SSD/NVME: Samsung 980 2TB
CPU COOLER: Ventoo V5
CASE: Antec P280
GPU: PNY 5070Ti
RAM: 32 GB DDR4 3600
PSU: Seasonic 750 Gold
This is how I'm running the 6900XT during this heat:
Basically I found maximum folding stable clock for 800mV.
so how does one learn or train to be be one of the folding.  i'm quite curious
CPU: ryzen 9 5950x
RAM: pny 3733 16-19-16-19-36
CASE: phanteks p600s
WC PUMP: alphacool d5
No AMD cards will be tortured this weekend. Haha. Started the comp with 2 cards, then 10 minutes later Mother nature came thru very upset. My electricty shut off 4 times in a 30 minutes period luckily they were short and back to business as usual. Fingers crossed.
GPU: 6800 XT
CASE: Antec P280
GPU: PNY 5070Ti
You mean to join as a folder?
It pretty easy just have to download the software here : https://foldingathome.org/?lng=en
Setup an account save your passkey
And add the team 239902 In the software to fold for the team here.
WUs I'm getting are pretty inconsistent as far as PPD goes, at least compared to what I'm used to. The last time I folded, I was consistently getting 2.2-2.5M PPD but over the last few days, it's been jumping between 1.2-3.5M PPD.
Power went out here too but only briefly. Some extreme lightning storm after some extreme heat and humidity today. Internet was out for a bit too.
Yeah pretty much just go here:
https://foldingathome.org/start-folding/?lng=en
Like said above, make a folding name, and enter our team number 239902. Using a pass key will allow you to get huge bonus points for quick return.
https://foldingathome.org/support/faq/points/passkey/?lng=en
Your hardware in your main rig is very good for folding, but I would tune it for efficiency instead of all-out clocks. Folding eats electricity but you can still crunch units fast while conserving power.
Thank you Sir. Never crossed my mind to do that. Weird seeing a 6800 XT humming at 150 watts,  2224 mhz and 3.1 ppd
GPU: 6800 XT
CASE: Antec P280
GPU: PNY 5070Ti
@ENTERPRISE I see the tshirts are removed from the EHW store? I was going to give at least one away but I will have to change that to hat unless you can confirm that's fixed.
good run y'all
CPU: AMD Ryzen 7 7800X3D
RAM: DDR5 6000
GPU: EVGA 3080TI
OTHER: OWC TB3 Dock
MONITOR: Dell S2716DG
MONITOR 2: Viewsonic 27"
7 minutes ago, Cerberus said:
good run y'all
Indeed. Some humongous amounts of points and work units!
I'll roll the dice for my random winner tomorrow after I confirm with @ENTERPRISE about the t-shirt. @tictoc would you like to draw your winner yourself? If not, @Avacado has a cool wheel of fortune thing he can spin for you.
Content Creator
302 279
Ah dang, just missed 100 WUs and don't think I was catching Fluxmaven fast enough.
SSD/NVME: 3x SN850X 4TB
MONITOR: LG C3 42"
Don't you have a 4090? I thought you'd be way ahead since I was mostly just running the 4070ti. I did notice you finally running me down. Fired up the 3x 3090s for the last 4 hours of the comp to stay ahead 😂
You can start HERE. If you have any questions, most of us are pretty active on discord. I'd be more than happy to help you get it running if you hit me up there.
It's nice that I had good folding weather all weekend. It's a shame I'm a moron and switched my computer off for the first night, not realizing that if I do that, the folding stops. At least I remembered to not switch it off for the other two nights.
Alrighty, I pm'd @tictoc to pick his winner for the graphics card.
For my donated prize, it looks like the t-shirt is not available at this time so I'm switching that to either a hat, or a mug+coaster. The winner of that is @HaRdLy007 so Jeff pick the design you want from the EHW store and PM me.
For next month I'm looking around August 19-20th and I'll announce that around the beginning of the month or so.
Thanks everyone for the great work!
Content Creator
302 279
Totally didn't forget to restart my folding client after playing VR for a bit 😄
MONITOR: LG C3 42"
Good foldathon guys.
Congrats!
