I think I'm ready for an EPYC system
HeyItsChris
Does anyone know what the most powerful/ economical cpu would be for a simple system for gaming but on the side lots of encoding & cpu work.
I want at a bare minimum 24c/48t because I want to surpass the 3950x on total compute horsepower, not necessarily IPC.  I just want more than a 3950x/5950x on a budget with a Supermicro motherboard ITX if possible with say 64GB RAM.
I'm not sure what my budget is yet but I spent way too much on my 3700X system, at least my parents made me feel that way.
I'd prefer a 32c/64t chip on a ITX Supermicro board unless ASUS makes an EPYC board at a bargain value?
A 13900k is mostly your only option. Server cpu are either overpriced or ways too slow.
I need a lot of threads & I only use AMD hardware & decent AMD EPYC IPC for encoding tasks, primitive encoding tasks like H264, H265, among older stuff as well.
It needs to game faster or equal to a 3700x @ 4700Mhz all core but smoke it on any other task.
What do you think this board would look like on the back of the IO plate?  I never install an IO plate anyway, just wondering if it would fit even know it says Proprietary.
ASRock ROMED4ID-2T
So far I got my eyes set on this board, but just not so sure about the RAM & also the cooling of the CPU...  I wanna get the AMD EPYC 7H12 64c/128t chip for like 750 or something like that maybe.  I'm sure it has more power than a 13900k in multi threaded tasks like specifically encoding?
Thanks for the reply.  I think I can afford the board, ram, cpu, and cpu cooler.  It's just i'd like to wax a 13900k on multithreaded tasks like for instance any & all CPU only encoding jobs on all Video Converter Applications of any & all types.  One I like to use is Bigasoft Video Converter I think it's called among others thats just one I use on occassion.  I use others more like MediaCoder PRO & Handbrake.  I find the CPU only jobs yield higher quality...
