Registered users can:聽
How to playback .DTS songs on MX Player Or Other Player On Android?
I installed the custom audio codec in MX Player for DTS & Dolby Digital among others.聽 I can playback movies in DTS but not music in .DTS RAW format for some reason it passes through Dolby Digital 5.1 rather than DTS 5.1 on my receiver.
Movies playback DTS but .DTS songs passthru DD 5.1 instead, like MX Player or the FFMPEG custom codec isn't working properly?
No Idea on MX Player but have you tried VLC Player ?
拢3000
拢3000
Do you have a receiver & possibly a .DTS music file on your system you can test on your system to see if the receiver picks up the DTS bitstream?
I tried VLC, same thing just outputs a DD 5.1 bitstream vs DTS 5.1 bitstream.
It must be a Android limitation not to be able to bitstream a .DTS song?聽 DTS sounds really buggy on my system with my HISENSE 43A6H google tv 4k android 11 arm v7a.
Maybe you can test the attached file?
Rename the .zip to just .dts as it was the only way the site would take, uploading on my Hisense 43a6h google tv 4k arm v7a 32bit quad core 1.5ghz mediatek chip android 11 crashes using a .zip on microsoft edge for android latest version & firefox worked though.
POWERS_-_Just_Kids_1400kbps_24dbRollOff_hipass_lopass.dts.zip
Edited by HeyItsChris
POWERS_-_Just_Kids_1400kbps_24dbRollOff_hipass_lopass.dts.zip 45.01 MB聽路聽0 downloads
Sorry, I will not be able to test as I do not have the setup to do so. I have no idea if it is an Android limitation specifically. Have you looked that up as that would be the first port of call because if Android does not support it, no amount of players/codecs will help.
拢3000
拢3000
