LG Cx48 Question
bwalker36
So I love this thing, but today I noticed that there is about a quarter inch on both sides that isn't utilized with my PC.  I only noticed becuase a UI element of the tv was showing where I thought the screen ended haha.  Is this normal due to aspect ratio or something?  I tried googling but I failed to find anything.
It only seems to be on the left side of the screen.  Additionally I use two monitors with the secondary monitor being on the left of the LG.
Edit 2:  Its probably only an 1/8th of an inch and definitely only on the left side.
Edited by bwalker36
CPU: 12700k
MOTHERBOARD: Asus Tuf Z690 D4
GPU: EVGA 3080 FTW Ultra
SOUNDCARD: EVGA Nu Audio Pro
Not sure I understand what you mean exactly. Maybe a picture would help?
I have both a 48" C1 and a 42" C4 and they both feature image shifting which is one of those anti-burn in features where it periodically slightly moves the whole screen a few pixels this way or that way. Is that what you mean maybe?
I was wondering that as I did more reading.  Well I can't take a picture now cuase its not doing it.  But it seems like the pixel shift.  There is like a very thin line where the screen just looks off.  I'm not missing anything on the screen that I can tell.  I notice the shift when it happens so I'll just keep on eye on it.  I think its the first time I noticed and it was just jarring to me hah.
CPU: 12700k
LG OLEDs support true, cinema 4K (4096 x 2160) and consumer, Ultra HD 4K (3840 x 2160).
You're likely noticing two columns that are 128 pixels wide on both sides of the display whilst using Ultra HD 4K (3840 width).
EN.WIKIPEDIA.ORG
Appreciate the responses.  Its like it magically disappeared now hah.  My goal is to forget I ever noticed anything.  I think I'm going to downsize in the near future and go to the 42 assuming its not a worse TV and put this one somewhere else.  I feel its a little too big.
CPU: 12700k
Basically exactly what I did. The 48" is in the living room now and I use the 42" as my monitor.
