[pcgamer] ASRock figured out a way to overclock Intel's locked non-K Comet Lake CPUs
"ASRock BFB (Base Frequency Boost) technology allows users to install non-K series CPUs on selected ASRock 300 and 400 series motherboards (even non Z models) and enjoy the base frequency boost with the hidden power of processors immediately," ASRock says.
By altering the PL1 value, ASRock is essentially tricking a CPU into running at a faster base frequency than it otherwise would. For example, the Core i9-10900 is a 65W CPU with a 2.8GHz base clock. ASRock's BFB mechanism pushes the TDP above its default setting, up to 125W, at which point the CPU apparently thinks it should be running at 3.7GHz.
1.6k 943
Wont last long before intel make a update for motherboard manufacturer and says it not allowed like they did in the past.
