Out of Beta
i was in still in beta... many many eons ago when it first began lol
  • BWG pinned this topic
1.3k 686
7 hours ago, u3b3rg33k said:
FYI i'm down for the count at the moment, my machine won't pass the bios at default settings. I may be able to temp with my W6600 Pro, but for the moment I am not folding.
Oh no! After how long with no issues?
1.2k 1,149
Ok well I finally got my 500 passes for the FirePro W2100. Shall I unleash the Kraken?
I mean it is (was) an x58 system, so that's kind of a loaded question 😬
but it had been fine folding for a while, but I've known the system was EOL. I was hoping for a bit more time before I had to start building a new one.
1.2k 1,149
What's your status as far as getting an ETF rig back up? I can run an additional client on either a GTX 750 or HD 7850 for December if needed until you come back online.
@Supercrumpet
@Supercrumpet
Somehow managed to miss this post. Would this still be doable for you to run the 7850 in AMD @damric, and what's your status @u3b3rg33k?
1.2k 1,149
Yes I think I can do this since it's already folding anyway.
@BWG Can I just use my other folding key for that one? I'll pm you.
@u3b3rg33k No worries just let us know when you get it back up and you can tag back in.
I should be folding. config is a bit weird, and you may have to delete a single CPU WU from when I started (not deleting WU but hit finish and pause-on-start until I can clear the slot).
I still have to figure out auto-login so folding starts after reboot. the normal method doesn't work, so I'll have to try the regedit method.
1.2k 1,149
Ok good so @BWG cancel putting in my HD 7850.
Ugh on a side-note, I'm  probably going to miss some points. I just checked on my client on the APU and it failed WU so I'm going to have to re-tune that OC.
Edited by damric
I see points on the board, glad you got things working again.
I'm still working on getting audio and HID reliable.  temporarily using the demo version of VirtualHere with a logitech unifying receiver. that seems to work fine.
I'm using my monitor's sound device over DP for stereo sound, but it has glitches. I may try something like PulseAudio, SoundIt, or Icecast.
steam streaming off this worked fine (so there's hope for those methods), but I really want my 3.1 audio vs stereo.
Edited by u3b3rg33k
On 13/12/2021 at 14:32, u3b3rg33k said:
Got my new USB card, so far no issues with sound or HID!
Nice! Always good when little fixes like that work out smoothly.
  • 4 weeks later...
1.3k 686
@Hackswordhas decided to join with his 1060. Welcome! Your team is full, and I got your 'cptn' to start folding again. You're full speed again.
Thank you @Hacksword for coming onboard and thank you @BWG for keeping us organized as always!
When I was home with my 24/7 folding rig I intended to do a CPU/mobo swap from the ancient FX4300/970A to my old 1600X/X370. Lots of snags though, I failed to realize that I didn't have an AM4 bracket for the cooler I intended to use, I didn't have any available DDR4, and some other small details as well. Worked around everything but the final issue, which is that my remote software just wasn't interested in working after reinstalling Windows. I ran out of time to troubleshoot and had to return to my apartment two hours away. So that PC just isn't running right now. As a result, I'm running on a 2080 Ti that is in my apartment currently. I'm planning on returning home in a week or so to fix that, then we'll be 24/7 again.
Anyways, the OP has been updated to reflect Hacksword's entry and my GPU swap as well.
Thanks for having me. I am going to keep folding at stock for now (until I get a day off) and then I am going to crank up the OC and hopefully start putting some real points up.
CPU: AMD Ryzen 9 5950x
MOTHERBOARD: X570 AORUS Elite
RAM: 64GB G.Skill 3200
GPU: AMD 7900XT
1.3k 686
I just noticed the profile pic is the RX7 instead of the RX8 😉
Can't be 'EXTREME' Stock 😉
The '87 RX7 is my baby. The RX8 is just a fun little project 🙂 Yeah, It should be tomorrow that I have time to turn up the clocks to EXTREME levels 😛
GPU: AMD 7900XT
Hopefully it stays stable, but from testing today it looks like 2184mhz on the core is looking pretty alright.
GPU: AMD 7900XT
soooo, I think I am going to have to put Linux on this ETF machine. It currently has windows 10 home and it is constantly rebooting for freaking auto-updates. It is driving me nuts. Sorry for the inconsistent points for the time being, but it always seems to think it is a great time to reboot while I am at work. There may be a day later this week where I am down for a few hours while I install Ubuntu or a similar distro. Would you like to coordinate a substitute for the down time, or do you guys think it will be fine? Let me know 🙂
GPU: AMD 7900XT
Personally, I'm not too concerned with that much downtime for this month. I'm already having a pretty mediocre month since my actual folding rig isn't up, so that PC will be getting some downtime as I use it for other stuff occasionally. But, if it's convenient to swap for that intermediate period, I certainly wouldn't stop you.
Edited by Supercrumpet
