Leak shows RTX 4090 at 3.0 GHz, 20K in TimeSpy Extreme
The graphics card received 20192 points in 3DMark Time Spy Extreme. With this result, this GPU is 78% quicker than the current NVIDIA Ampere series flagship, the RTX 3090 Ti, and 90% faster than its predecessor, the RTX 3090. Intriguing is the fact that the leaker has supplied GPU clock and temperature data. It allegedly shows the GPU achieving a frequency of 3015 MHz, which is an extremely high clock for a GPU. The GPU was tested at 30°C ambient temperature, while the GPU temperature oscillated about 55°C, according to the individual (but we can see it went big higher). According to the leaker, the graphics card is air-cooled and massive.
https://www.guru3d.com/news-story/alleged-leak-shows-geforce-rtx-4090-gpu-at-3-ghz-with-20k-points-in-timespy-extreme.html
But can it run...
