Indium Thermal Pads?
damric
I get random emails from these shops and this one caught my interest. I did not know they made these. Anyone ever tried one?
I have not used them personally, but it seems like overkill "IF" the rated specifications are true. You are also introducing 2 extra layers of thermal transfer. RAM IC > TIM > Indium pad > TIM > Heatsink.
I wager it wouldn't be much better than using a really good 11 or 18w/mk pad that is the traditional RAM IC > Pad > Heatsink model.
It is a curious product though. It's liquid metal in a pliable solid format.
What I was thinking when I saw this...
Avacado going to use these on DDR5 experiment with
WWW.EBAY.COM
1 Heatsink (Because each batch of pure copper material is different, the appearance of the product may have color difference). Colour: copper color. Material: pure copper.
