HDR images issue
Is it possible to fix the issue with HDR images? It seems like the site doesn't support HDR so when an HDR screenshot is posted, it will appear oversaturated.
  • UltraMega changed the title to HDR images issue
Hey Ultra,
I can look into it. What file extension is it using?
Thanks,
E
拢3000
  On 10/01/2023 at 10:51, iamjanco said:
@UltraMega If you don't mind my asking, how are these 'HDR image' screen shots being generated/created (e.g., app(s) used to take such screen shots and a summary of the workflow used to do so as well)?
Just screenshot I take with either steam or the AMD control panel.
  On 10/01/2023 at 09:47, ENTERPRISE said:
Hey Ultra,
Thanks,
E
When I checked on this I noticed the images look over saturated on my PC as well. Looks fine in game but screenshots are over saturated. Very weird, HDR is messy. Sorry for the confusion.
^Thanks for the update. Yeah, I was pretty sure the problem has nothing to do with the web site; hence, the reason I asked.
Are you using Win 11?  If so, see the info at the following links:
Windows HDR and screenshots
Over-exposure in screenshots and recordings with HDR in Windows 11
Thanks for the update guys 馃檪
拢3000
