EXTREMEHW First Annual 96 Hour Folding Challenge, March 17th-20th 00:00 UTC
damric
43 Attachments
2 hours ago, 80-watt Hamster said:
IN 80wattHamster
2 minutes ago, StrunkenCap said:
In, StrunkenCap
Welcome to EHW, thanks for swinging by our community and pitching in 🙂
6 minutes ago, 1freedude said:
IN 1freedude
Welcome to EHW. Thanks for joining our competition!
$5500
GPU: MSI RTX 3060 Ventus
CASE: anidees Ai Crystal Cube
PSU: OCZ ModXStream 550w
CPU: i5-7600 4.5GHz
10 minutes ago, Avacado said:
But my hair is more curly, and more of it.  I put up a pic in the lounge general nonsense at tpu.  I'll see if I can find it.
Edit, here it is, but ya gotta sign in
https://www.techpowerup.com/forums/threads/general-nonsense.232862/post-4911210
Edited by 1freedude
login member wall
9 hours ago, Alex said:
Putting that 7950X3D to work :drunk:
Whoa, 3.4M PPD.  What's the PPD from the 7950X3D and the 1080Ti individually?  I'd almost also wanna experiment with dedicating 31 threads to one F@H core vs. 8, 12, or 16, but I don't know what gives the maximum PPD.
I'm deciding between 7950X or 7950X3D.
Edited by Broseph
12 hours ago, ENTERPRISE said:
Cheers 🙂Worth the investment bud. While I tried to get a 10Gbe card to work in it (Should I get above 1Gb Internet one day), it would not have it and after a lot of effort, decided it was easier to go with the I350-T4. I am sure you could get it to work once you tied down the right model and go through the effort, but the Speeds I get from my ISP (1GB) is more than enough anyway. You can pick up the HP Thin Clients on Ebay for dirt cheap, the I350-T4 is also really cheap but fantastic, I mainly got it as most of the Intel NIC's have acceleration on them which is important for things like network inspection etc (Suricata). otherwise you can end up with a bottleneck.
I went with as much RAM as I did as I was not sure how many services I would be putting through it and the overhead. I run Suricata, pfBlockerNG. Squid Proxy Server with a large amount of host lists etc and I only hit 13% usage lol. So yeah, 8GB would see you more than comfortable. You would also get away with 4GB likely.
Yeah, getting a 4-port 10Gbe card would be ideal, but I don't think the T730 cooling or power delivery can handle it, so I may just go with plain ol' Gigabit.
I overspent like $700 on my first pfSense build in 2013:  Xeon CPU, 2x8 GB of DDR3 ECC RAM, Supermicro motherboard for 4-port Intel i210 Gigabit NICs, 2U Rosewill rackmount chassis.  It was rock solid but a lightning storm in 2019 destroyed it (the surge entered the house through coax cable then traveled through the cable modem and fried everything attached to Ethernet.)
While my ultimate goal is to someday build a solid 1U Supermicro pfSense router that has plenty of 10Gbe, SFP+, and 25-Gig (SFP28) connectivity, something like that would be over $1000, and I'm currently renting and we're on 200/20 Mbps cable Internet and the house is not wired for Ethernet yet, so the HP Thin client idea seems cheap enough for current needs.
I mainly used pfBlocker with lots of malware filtering rules, no Snort/Suricata yet (learning curve and fine-tuning!), and 24/7 OpenVPN gateways with policy-based routing for all my WAN traffic, and FreeRADIUS for WPA2-Enterprise EAP-TLS WiFi (certificates everywhere and mutual auth).  I can't wait to have pfSense running again so I can switch from WPA3-PSK to WPA3-Enterprise 😄
I should be good with the 8 GB RAM in a thin client build and in the future I can re-purposes the machine as a small Proxmox device or something.  I've been putting off my pfSense rebuild for almost 4 years now.
But I digress.  Fold on!  🤘
I set a 5950X to run 28 of 32 threads. I had to set LLC to high and disable PBO, otherwise it would keep crashing. Even ECO mode did not agree with f@h on my 5950X. Also running a 6900XT on that rig.
CPU: Ryzen 9 5950x
MOTHERBOARD: B550 PG Velocita
RAM: 4x8GB Ballistix
Cheap
CPU: Ryzen 5 5500
MOTHERBOARD: X470 TAICHI
PSU: EVGA SUPERNOVA P5
GPU: Quadro M4000
GPU 2: Quadro M4000
GPU 3: Quadro M2000
1 hour ago, 1freedude said:
Sure thing, but you'll have to blame damric for inviting the riff-raff!
We're a riff-raff haven here. Apparently some forums thought we were too greasy and dirty and deleted my invitation posts for the event. W1zzard at TPU was quite helpful though. That guy knows what's up.
Shoutout to LTT, Guru3D, EVGA forum, f@h forum, HWBOT, and anyone else that didn't delete my spam!
Edited by damric
  • Respect 8
CPU: Ryzen 9 5950x
Cheap
CPU: Ryzen 5 5500
GPU: Quadro M4000
GPU 2: Quadro M4000
GPU 3: Quadro M2000
Judging from the screenshot, I'd guess about 1M for the 7950X3D, which leaves 2.4M for the 1080Ti
CPU: Intel Core i7-13700KF
CPU COOLER: Alphacool Eisbaer Pro Aurora 420
MOTHERBOARD: MSI Pro Z690-A DDR4
RAM: 2x16 GB G.Skill Trident Z RGB DDR4-3600 CL14
SSD/NVME: Samsung 980 Pro 2 TB
GPU: Gainward RTX 4080 Phantom
PSU: bequiet! Dark Power Pro 12 1200W
CASE: Fractal Design Meshify 2 Dark Tempered Glass
CPU: Intel Core i5-10400F
CPU COOLER: Prolimatech Genesis Black Edition
FANS: 2x Alphacool Rise Aurora 140
MOTHERBOARD: MSI B560M-A Pro
RAM: 2x8 GB G.Skill Aegis DDR4-3200 CL16
PSU: bequiet! System Power 10 750 W
GPU: MSI RTX 3070 GAMING X TRIO
CASE: Sharkoon TG6 RGB
in
rogueleader
CPU: Ryzen 7 5800X3D
MOTHERBOARD: Asus Crosshair VI Hero
RAM: Corsair Vengeance DDR4-3200
GPU: ASUS ROG STRIX RX6900XT LC
PSU: Corsair HX1000i
SSD/NVME: Samsung 960EVO 250GB
SSD/NVME 2: Samsung 860 EVO 1TB
HDD: Seagate Barracuda 2TB
CPU: Ryzen 7 3700X
MOTHERBOARD: Gigabyte X570i Aorus Pro WiFi
RAM: GSkill Trident Z RGB DDR4-3600
GPU: Gigabyte GAMING OC RTX 2080 Super
PSU: Corsair SF600
SSD/NVME: Samsung 970EVO 1TB
CPU COOLER: Corsair H100i Pro
CASE: Corsair Crystal 280X
CPU: Xeon E3-1231V3
MOTHERBOARD: Supermicro X10SLL-F
RAM: Crucial DDR3-1600 ECC
PSU: Seasonic G450
HDD: RAID 2x Seagate ST4000 4TB
CPU COOLER: Noctua NH-L9i
CASE: iStar D-213-MATX
FANS: Noctua A8
18 minutes ago, Rogue Leader said:
in
rogueleader
Glad to have you representing Tom's Hardware!
Just over 8 hours to go until challenge starts, so hopefully everyone is lighting off the crunch machines to work out any last minute kinks.
I see that a new beta client for folding@home has been released. I'll test it out after the competition ends.
CPU: Ryzen 9 5950x
Cheap
CPU: Ryzen 5 5500
GPU: Quadro M4000
GPU 2: Quadro M4000
GPU 3: Quadro M2000
Hope to join you guys in a future comp when I have a space I can run rigs for this.
Knock it out of the park everyone! :wheee: :music_rock:
In, Another_Crafter
gl everyone!
CPU: Ryzen 5800x
MOTHERBOARD: Gigabyte x570s Aero G
RAM: 4x8GB Crucial Ballistix DDR4 3600mhz [Rev. E]
GPU: MSI Nvidia RTX 3070ti Ventus
SSD/NVME: Samsung 970 Evo Plus 2TB
SSD/NVME 2: Samsung 970 Evo Plus 1TB
SSD/NVME 3: SK Hynix Platinum P41 2TB
CPU COOLER: EK Basic 360mm AIO
CPU: Intel i9 9820x
MOTHERBOARD: EVGA x299 Dark
RAM: 4x8GB Teamgroup Vulcan Z 3200mhz
GPU: Gigabyte Nvidia RTX 2080ti Turbo
GPU 2: Gigabyte Nvidia RTX 2080ti Turbo
GPU 3: Asus Nvidia RTX 2060 6GB Dual
PSU: Corsair RM750
PSU 2: Corsair RM850
33 minutes ago, Torell said:
Woot!
How many here from EVGA forum?
CPU: Ryzen 9 5950x
Cheap
CPU: Ryzen 5 5500
GPU: Quadro M4000
GPU 2: Quadro M4000
GPU 3: Quadro M2000
2 hours ago, Another Crafter said:
In, Another_Crafter
gl everyone!
Welcome 🙂
5 hours guys!
$5500
CPU: i5-7600 4.5GHz
Welcome to everyone joining. Competition starts in 3 hours guys!
$5500
CPU: i5-7600 4.5GHz
