OLED pixel refresh question
Go to solution Solved by thermotto,
Premium Platinum
777 449
Hi guys. I have a 77" LG CX series OLED TV for modern (and some not so modern) gaming and console gaming as well as home theater.
My question is simple: we've had the TV since June 2021, so that's two years of owning it.
In the menu for the TV there is a pixel refresh option. I am wondering if I should use it or not? The picture quality and brightness and color are all okay and I haven't really noticed a difference compared to when we first got it. There aren't any dead or stuck pixels that I can see...
Do I need to do a pixel refresh or not?
Thanks in advance.
$5500
RAM: G.skill Flare X 6200MHz 30-36-36-36-108 subtimings tuned
GPU: MSI RTX 3060 Ventus
CASE: anidees Ai Crystal Cube
PSU: OCZ ModXStream 550w
CPU: i5-7600 4.5GHz
  • Solution
If you don't have any issues, then you don't need to run it manually. It will run on its own after every 2000 hours (IIRC) of accumulated usage.
I've got a 55" C9. I ran the refresh manually just once to clear up some image retention. Otherwise I have let it handle the refresh automatically.
