Best Graphics Card Repair Business in the United States?
HeyItsChris
30 Attachments
  On 13/03/2024 at 23:37, HeyItsChris said:
 Can you confirm the cfm output of the AUB0712VH vs AUB0912VH?
Thanks again
Edit:
The 70mm AUB0712VH appears to be 31CFM (but, I cannot find a 1st-party datasheet)
The 92mm AUB0912VH is ~68CFM
Edited by LabRat
Got the AUB0912VH's installed and performance wise, not really impressed.  I think I need more CFM to cool it down more.
I think it cooled the hotspot down by only possibly 5*C or less at load, but more thorough testing needs to be done.
Why can't I open and run 3dmark on steam?  It freezes my whole system every its **Scanning System Info**?
Powercolor Red Dragon AMD Radeon RX Vega 56 with 3x 92mm Delta AUB0912VH fans installed.jpg
Edited by HeyItsChris
I guess the performance is pretty good.  It's hitting nearly 1800Mhz Core Boost @ 250 Watts 250 Amps @ 1.125V @ 84*C TEMPERATURE LIMITS ACROSS THE ENTIRE BOARD.  The Hotspot only hit 77.5*C, which is quite nice I'd have to say.  I was just hoping for 67.5*C instead.  Maybe I need 120mm Deltas instead.  I need lots of pressure & cfm right?
So for some reason I cannot undervolt unless I set the memory voltage in AMD Radeon Settings because setting the undervolt in Vega64SoftPowerTableEditor it results in like 1.150v rather than 0.900v.  Also why isn't it achieving greater than 1536Mhz DPM 6, not 7 which is set to 1700Mhz?  I have the TDP & TDC @ 280W 280A.  Thanks
